how do u rewire ur Bumper lights
Old Aug 24, 2000 | 07:52 AM
tunedup's Avatar
someone mentioned htat if u rewire them they will always b on ..
howwever hte thing i dont understand is when u signal... nathing is gonna happen the signal is not gonna work.
am i correct on this ????
*can someone also give me a brief summary on how to do the rewiring for those lights ? *
Old Aug 24, 2000 | 08:02 AM
tunedup's Avatar
Whats the bulb size for the signal onthe bumper ?
is it illegal to put clear bulbs in clear lenses ? for the signal??
b cuz i wanna get super whites in thtere
Old Aug 24, 2000 | 08:06 AM
Eman97SE
Very nice site doug, excellant job! n/m
n/m
Old Aug 24, 2000 | 08:07 AM
tunedup's Avatar
the dual socket ? i can get that from home depot rite?
it doesnt have to b a car performance store or something ..
Old Aug 24, 2000 | 08:16 AM
tunedup's Avatar
one last thing
u know how u have to pull out the power when u are takin out the blinking piece..
when u put a new socket what hapeens to that .. it wont plug in to where its supposed to know get what imsayin
OR
im understandin wrong
u unscrew where the bulb is and then inside that there the socket
but even then i have to cut the plug off b cuz i have to strip the wires... <----_ ???
is this makin sense ???
Old Aug 24, 2000 | 08:34 AM
tunedup's Avatar
ok man i get that
but u know how rite now theres a plug that goesd in to the socket *the power*
afete the mod its no longger gonna b a plug ..
its just gonna b taped up wires
rite> ?
Old Aug 24, 2000 | 08:35 AM
tunedup's Avatar
the socket how would it screw in to the lens??
is it thesame type of screw???
Old Aug 24, 2000 | 08:48 AM
tunedup's Avatar
arite thanx sooo much
thats all i wanted to know ...
the socket should screw in to the lens Rite????
the ones i can get from homedepot do u think they will have the screw in to the lens?
Old Aug 24, 2000 | 08:58 AM
tunedup's Avatar
and the pepboys one screws in easily>
Old Aug 24, 2000 | 09:04 AM
tunedup's Avatar
Not a Problem man
Im gonna do it with trial and error ...
the wires that are actually goin into the socket are the positive wires 8 adn 27
the one thats goin to the side is hte negative..
the negative to the negative ..
and then other two i just gotta test and see ..
Old Aug 24, 2000 | 09:28 AM
wicked1044's Avatar
what about if you have the alternating re-wire done?? will this still work?
Old Aug 24, 2000 | 09:35 AM
1MAX2NV's Avatar
Re: arite thanx sooo much
YOu can get the socket from Pep Boys...NOT Home Depot. ONly modification you need to do is trim of a little piece of tab that's getting in the way. You will see what I'm talking about when you have the socket and you try to plug in. Everything match up except for that little tab.
Old Aug 24, 2000 | 09:36 AM
tunedup's Avatar
doug isnt tha wut im doing???
Like 27 w all time 8 w blinkin...
what am i gonna get when i do ur method that was posted on the site ?
Old Aug 24, 2000 | 09:41 AM
wicked1044's Avatar
i think i'm going to try it. the alternating blinker lights look pretty cool,but i would also like to have my turns always on .
Originally posted by doug
the what? you mean doing the 27w for on all the time and the 8 w to blink?
I am not sure.. you may try it.. you may blow a L. Tail light fuse in the process but try it..
Old Aug 24, 2000 | 09:46 AM
tunedup's Avatar
Re: Pepboys
We dont have pepboys here...
where else do u think i cna pick it up from... I Live in TORONTO... Home depot or other hardware stores wont have it /?
Old Aug 24, 2000 | 09:47 AM
tunedup's Avatar
Re: Pepboys
where else do u think i cna pick it up from... I Live in TORONTO... Home depot or other hardware stores wont have it /? * socket with the screw lid *
Old Aug 24, 2000 | 09:57 AM
tunedup's Avatar
Hey Doug
Would it b possible to stick iwth the single socket
and just get the blinker to blink at 27 w when i signal and
the light to always stay on at 27 W
Old Aug 24, 2000 | 10:06 AM
wicked1044's Avatar
Re: Hey Doug
thats what i'm trying to do...
Old Aug 24, 2000 | 10:12 AM
tunedup's Avatar
Re: Re: Hey Doug
i thought u were tryin to get ur side markers to blinkwith tem too
Old Aug 24, 2000 | 10:14 AM
wicked1044's Avatar
the single could stay on all the time and blink.
Old Aug 24, 2000 | 10:17 AM
tunedup's Avatar
How could it DO THAT???
Doug just said u cant get it to blink and stay on all the tiem!!!
Old Aug 24, 2000 | 10:22 AM
wicked1044's Avatar
it will be on and when you signal it will blink. shut off and on. with the dual the light will never go out, just a briter light will blink right?
Old Aug 24, 2000 | 10:27 AM
tunedup's Avatar
I DOnt know i want to get dougs attn so we can ask him
Thats wht i wanna do
Old Aug 24, 2000 | 10:35 AM
tunedup's Avatar
Re: so what doug is telling us to do will doo.......
thge thing doug is telln us to do will do waht ??
Old Aug 24, 2000 | 11:32 AM
wicked1044's Avatar
doug's way will keep the turn signal on when ever you turn on the lights. for turning it really dosn't blink on and off, what happens is the briter watt will come on with the 8 watt. what i have now is my blinkers alternate (look pretty cool) but i am now trying to also get my turn to say on and alternate...i'm trying to see if i can keep the sockets i have w/o the dual.... we're on fire now
Old Aug 24, 2000 | 01:34 PM
Slickismax's Avatar
DON'T WASTE YOUR MONEY ON A NEW SOCKET!!!!! Just switch with the corner light. Modify the socket slightly to get it to fit, and then switch your bumper turn socket with your corner socket. Then you will have 27W bright corners plus constant 8W bumper turns and they will blink 27W bright!
Old Aug 24, 2000 | 01:46 PM
tunedup's Avatar
Slick is max
can u explain that one more time ..
i did my corners yesterday
they look great man thanx for all the help
Old Aug 24, 2000 | 01:51 PM
Slickismax's Avatar
Okay, I meant that you take the dual element bulb and socket from the corner light and switch it with the single element bulb and socket from your bumper light. If anyone needs to know which wires to solder to which, I will go and take apart my car to see for you. And, yes, the 97-99 Max's have a dual filament socket and bulb in the corner, they just don't have a wire going to the bright 27W filament.
Old Aug 24, 2000 | 01:56 PM
tunedup's Avatar
i understand ... the wires..
that i did with the corner lights ... like i did the opposite of how it came stock ..
like the wires i switched them so brown went with black and vice versa and then negativ wire went with the negative wire..
in this situation the signallin lite i am gonna do the same thing???
and the side bumper lite is soo small how is that gonna signal 27 watts?
Old Aug 24, 2000 | 11:56 PM
Slickismax's Avatar
Well, the side light will not blink at all. You just leave that alone. There isn't a way for it to blink 27W because the design of the lens won't accept a dual filament bulb. What you end up doing is running a wire from the constant corner light to the 8W part of the dual filament harness you switched with the corner light. You can only have a constant 8W bumper light that blinks 27W if you switch the two harnesses, meaning the corner light harness and the bumper light harness. Basically, since the turn signal in your bumper is a single element 27W bulb, and all you want is a 27W constant in your corner light, you put it there, and since you want a constant 8W in your bumper that blinks 27W, you put the dual filament harness in the bumper that was in the corner light.
Here's a pic of what it will look like with your lights on, and BTW, I don't know why my sidemarker looks purple! Arghhhh...stupid cheap-a** hyperwhite 8W!
Old Aug 25, 2000 | 07:07 AM
Will the harness switch work on a 95?
I am gonna go ahead and try the switch, I got the corners done by my headlights yesterday.
Old Aug 25, 2000 | 07:21 AM
tunedup's Avatar
Re: Will the harness switch work on a 95?
Black max... cna u do it and like take notes i would appreciate it
b cuz i am clue less about this stuff ...
if u could just take like 5 pts down in Point form it would b much appreciated.
And yes it will work b cuz they have the same wattage harnesses i dont c a problem
Old Aug 25, 2000 | 11:52 AM
I got your back. I did the corners last night, and I will do the bumpers tonight. Give me you E-mail and I will mail it to you if you'd like. My E-mail is by by name..
Old Aug 25, 2000 | 01:22 PM
tunedup's Avatar
Re: Re: Will the harness switch work on a 95?
my email is jerky969@yahoo.com
the corner lites worked rite... cuz i can give u hand if they didnt
last nite i did my grill and i went to home depot bought aluminum mesh and made my grll
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
MaxLife17
Sep 8, 2015 02:36 PM
