Anyone know how to get JDM wheels?
Old May 30, 2001 | 11:31 AM
cyclemax's Avatar
I'm looking for an Enkei wheel in an offset not currently offered here in the us (45mm). Can anyone suggest a shop/supplier in Japan?
Old May 30, 2001 | 12:12 PM
cyclemax's Avatar
Bortex MII
I'm interested in the Enkei Bortex MII, 18x8 for my 99 Maxima. They're available here in the US, but in a 35mm offset, which will position the 235/40's out a little too much up front (I currently have 45mm offset).
They weigh in at under 18lbs ea. I also like the style and think the color would go well with the silver body.
Enjoy....
Old May 30, 2001 | 12:19 PM
1MAX2NV's Avatar
Re: Bortex MII
35mm probably will work for 18X8. 45mm?? What rim width? You wouldn't know until you bolt it up. I have 18X8.5 with 40mm with 235/40. 5mm difference.
Enjoy....
Old May 30, 2001 | 12:37 PM
cyclemax's Avatar
Re: Re: Bortex MII
It's available in 18x8. I know 35mm will "work", but would be 10mm further out than the 45mm I currently have. Doesn't sound like much, but makes a visual difference, especially with 235 tires. This is only a problem on the front, though- the rear has more clearance.
BTW, I like that fancy emissions plumbing on your intake manifold!
Old May 30, 2001 | 02:11 PM
1MAX2NV's Avatar
Re: Re: Re: Bortex MII
I still think you are better off with the rims sticking out more. You will have more room when you decide to get a big brake upgrade. The outer lip of 18X8 with 35mm is probably in the same position as my 18X8.5 with 40mm.
Old May 30, 2001 | 03:08 PM
cyclemax's Avatar
I see your point, although the tire position is mostly what I'm concerned with.
So you are at 40mm, which means that your tire's tread edge is out 5mm more than an 8" 45mm offset wheel. However, your rim is .5" wider (12.7mm) which would be about 6mm per side, so the rim edge would end up in roughly the same place.
I think I'd still rather have the higher offset wheels, though. The only big brake upgrade I'm gonna get is when I bite the bullet and buy that 540i.
-Thanks
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
Redfox
Sep 28, 2015 10:41 AM
