Whats wrong with my hids?
Old Oct 17, 2005 | 05:24 PM
white97gxe's Avatar
I have an aftermarket conversion kit, not sure what brand because it came with the car. The drivers side lights up for about 20 seconds and then blinks a little bit and shuts off completely. Any idea if its teh bulb, ballast, ignitor or just the wiring?
Old Oct 17, 2005 | 05:28 PM
Tatanko's Avatar
Bacon Lover
Doesn't sound like it would be the wiring to me. If that were the case, I doubt it would come on at all.
Old Oct 17, 2005 | 05:31 PM
sean05's Avatar
loose ground maybe? my passanger fog light somewhat like that. sometimes it comes on then sometimes it doesnt. if it doesnt work then i tap it and bam it works. so idk i think i have a bad ground
Old Oct 17, 2005 | 05:40 PM
TXT-1's Avatar
Sounds like a bad ballast to me.
Old Oct 17, 2005 | 07:50 PM
Nismotic's Avatar
Always sunny in philly
also sounds like a bad ballast.
Old Oct 18, 2005 | 08:27 AM
maxgtr2000's Avatar
KH3 by popular demand
Are you running an aftermarket wiring harness to power both ballasts? If not that might be the problem. The kits say plug and play but you need a harness regardless. One ballast can pull over 60 amps at start up. The other problem is that it is a "kit". If there is no warranty you are up the river without a paddle. My motto is" No kit, retrofit". Anyone wanting hid at all needs to go to hidplanet.com/forums and read everything in the hiduniversity section to become more educated about it. The oem parts are cheaper even though they are used and outlast the brand new "kits" no matter what ANYONE tells you.
Old Oct 18, 2005 | 08:38 AM
C MAX's Avatar
i have 2 ballasts for sale if interested.
Old Oct 18, 2005 | 12:10 PM
Trurida18's Avatar
yea that does sound like a bad ballast
Forge277
Jun 13, 2016 09:26 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
Vistance
Sep 17, 2015 05:17 AM
