compression check...
Old Oct 20, 2005 | 02:45 AM
panda_1's Avatar
newb questions never done before, what do i need and what should i read, i know i need to pull the packs n plugs and crank bout 3 times at WOT, ne more tips or tricks?
Old Oct 20, 2005 | 10:26 AM
oldngivout's Avatar
Willing to learn
If the engine will run, it will give you better compression readings if you warm it up first. Then pull ALL of the coilpacks and sparkplugs. Try to crank the engine on each cylinder the same amount of time, like 2-3 seconds, with the throttle wide open.
You could also pull the fuel pump fuse while you are doing the test, just to be safe.
Old Oct 20, 2005 | 11:14 AM
C MAX's Avatar
before you do the test remove your fuel pump fuse while the car is running unitl it shuts off. crank it a few times to make sure it wont start then proceed to check ea cylinder. the reason for this is so the car wont start while your testing it. i would let them ea cycle about three cranks before checking the pressure. does anybody know the correct range of compression he should be looking for EX. 190 compression.
Old Oct 20, 2005 | 06:06 PM
panda_1's Avatar
and what exactly do i need to check the compression i.e the correct name of the tool?
Old Oct 20, 2005 | 07:42 PM
ExoticCreations's Avatar
Your local parts store sells the tool(Pep boys). It says on the package "Compression Check thingy"
Old Oct 21, 2005 | 05:13 PM
panda_1's Avatar
lol... is that the technical name for it? lol
Old Nov 22, 2005 | 02:08 AM
panda_1's Avatar
also, anybody happen to know what the cylinders should read when done?
Old Nov 22, 2005 | 10:44 AM
95BLKMAX's Avatar
I'm also interested in knowing this. Panda if ya want come over to the SW this weekend, and we'll check it at the same time. I wanna check mine and Nismology's.
Old Nov 22, 2005 | 12:18 PM
panda_1's Avatar
what day????????????????
Old Nov 22, 2005 | 12:25 PM
nismology's Avatar
I don't think the numbers matter as much as the difference between cylinders so checking it on a cold motor is fine as long as the numbers aren't too low.
Old Dec 1, 2005 | 03:17 AM
panda_1's Avatar
u fools never got back to me on a day! besides i found it in the FSM for my car, so now i know the proper numbers.
aw11power
Oct 10, 2021 04:57 AM
rbuswell
Nov 17, 2016 04:54 AM
Carlos A
Jun 9, 2001 05:19 PM
1FasMax
Dec 13, 2000 12:01 PM
