wheel making noise - need some help
Old Oct 31, 2005 | 07:43 PM
JeEvE's Avatar
My front passenger wheel makes a click/clunk noise in short incriments depending on speed. So when making a left turn or steering at all in the left direction it makes the clunk, clunk, cluck noise. It only makes the noise while giving accelerating (not hard), so if I let off the noise goes away.
I thought it could be the strut (D2 coilovers) but if letting off the gas makes it go away, it cant be that. It could also be the wheel bearing but the wheel does not have any play. Axles boots seem to be fine also. Anyone have any ideas what it could be? I know asking help on a problem based on a noise is stupid and difficult to determine so I will try to make a video by tomarrow night. Any help would be greatly appreciated. Thanks.
98 Maxima-everything has 110k miles except motor which has 9k
DE-K motor, 5spd trans, D2 Coilovers
Old Nov 1, 2005 | 05:05 AM
njmaxseltd's Avatar
CV joint is probably shot.
Old Nov 1, 2005 | 05:09 AM
Greeny's Avatar
¯\(°_o)/¯
Cv axle is bad.....
Old Nov 1, 2005 | 05:27 AM
JeEvE's Avatar
Hmm, that does seem very possible but wouldnt it still make the noise if im accelerating or not?
Old Nov 1, 2005 | 05:49 AM
Matt93SE's Avatar
STFU n00b!
not necessarily. they wear the most on the points of contact where you're accelerating. when you're coasting or decelerating, there isn't that much force on them from the engine, so there isn't a whole lot of wear. Thus, most of the time when you hear noise, it's going to be when you're accelerating.
Old Nov 1, 2005 | 07:12 AM
JeEvE's Avatar
Makes sense. Thanks for all the replies. Im going to order a passenger axle from raxles later today. Hopefully thats it.
Old Nov 3, 2005 | 12:31 PM
92black4dsc's Avatar
well i only have a 3 gen but i had that sound and it was the ball joint.
Old Nov 4, 2005 | 08:05 AM
stevo936's Avatar
could be wheel bearing, cv, or ball joint jack it up and have someone wiggle the wheel around while u look
Old Nov 4, 2005 | 10:18 AM
Larrio's Avatar
The Definitive AE Master
me and a few other maximas around here have the same exact symptoms. On one 4th gen we've changed:
1. wheel bearings
2. ball joint
3. axles
And it still makes that noise (only turning left and only while accelerating). The only thing left is the tie rod, which I was planning to disconnect from the front sway bar and see if the noise is still there.
Old Nov 4, 2005 | 02:41 PM
JeEvE's Avatar
Axle is already on the way from Raxles and it should be here monday. Im hoping thats the problem.
I have already checked play in the wheel so its not the wheel bearing. Maybe it could be the tie rod... Larrio, is the noise coming from the right wheel when turning left?
Old Nov 6, 2005 | 04:00 AM
97SEdriver's Avatar
this place is dead
When you planning on fixing it? Monday or Tuesday I might be able to help if you don't have enough guys already.
Old Nov 6, 2005 | 10:16 PM
Larrio's Avatar
yes, right wheel when turning left. Only when i'm on the throttle, once I let off it goes away.
unfortunately for me axles are not as replaceable.
Old Nov 7, 2005 | 02:22 AM
JeEvE's Avatar
Hmm, I guess Ill have to see after I replace the axle. Thanks for offering help 97SEdriver, axle is coming sometime today but after class im suppose to help a friend out with changing his clutch. So if I have some time after that, Ill do it, shouldnt take any more then an hour.
Old Nov 7, 2005 | 12:46 PM
97SEdriver's Avatar
this place is dead
I'm partly offering help because I know my passenger side CV boot is shot and soon enough the joint will be too, so if helping you helps me have an easier time when I have to replace mine, that's fine with me.
Tell me if it only really takes an hour, last job I did was a rear valve gasket replacement, and then Nissan screwed me and ordered the wrong valve gasket.
Just let me know.
Old Nov 7, 2005 | 04:36 PM
Nickel's Avatar
I just got my passenger side exle boot change to a new one but, now I hear a clack clack on mines.
I still have a werenty on my car he told me is the exles he going change them for me tommrow. but I dont trust them. cuz the they they fix my boot, when i got home I pop my hood and my engine had 3 chiken wings on top no lie.
so right after they fix my **** Ima go to pet boy or midas where the perfactionals be at. and have them check em out
Old Nov 7, 2005 | 05:55 PM
Matt93SE's Avatar
STFU n00b!
dude, that has got to be the most retarded thing I've heard this week!
Well, almost.... this guy just edges you out..
http://forums.maxima.org/showthread.php?t=438905
Old Nov 7, 2005 | 05:57 PM
JeEvE's Avatar
I didnt get a chance to replace mine today, doing the clutch job took up most of the day. 97SEdriver, whenever you decide to do your axle, I can come by and help out, just let me know.
Old Nov 7, 2005 | 06:12 PM
Nickel's Avatar
hey you think the 3 chiken wings that was on my engine could of mess something up?
Old Nov 7, 2005 | 07:34 PM
97SEdriver's Avatar
this place is dead
Dude, I would be VERY careful, chicken wing sauce, which is mostly vinegar and hot pepper, in the presence of engine oil and brake fluid can react and form a suspension this is essentially low grade PVC, which is poly vinyl chloride. The issue with poly vinyl chloride is that when heated to a certain point it gives off acetylene gas (the stuff they use for blowtorches), so clean that **** off!!
After you clean the stuff off wax your engine cover, some of the boys in the DC forum are teh masters of waxing teh engine cover.
Old Nov 9, 2005 | 01:13 PM
safari2005's Avatar
Same boat, but Front Driver side.
Old Nov 13, 2005 | 04:07 PM
JeEvE's Avatar
I replaced the axle with a Raxle this Saturday and it fixed the noise problem. The boot was not ripped or anything so maybe it was from the angle the axle was at when lowered on the D2s or just because they were old.
Old Nov 13, 2005 | 07:36 PM
97SEdriver's Avatar
this place is dead
Be careful with chicken wings!!!!
Couldn't resist, Sorry Nickel
JeEve,
how long did it take to replace the axle? Did you do both?
Thanks,
Old Nov 13, 2005 | 08:49 PM
JeEvE's Avatar
Didnt take long at all, I think it was under an hour. The only thing that took time was draining the gear oil and putting it back in. I only did the passenger side, the driver side should take less time since its shorter and there is no bracket. Let me know when you plan to do yours.
Old Nov 14, 2005 | 03:36 PM
GBAUER's Avatar
Did I hear someone needs help waxing their engine cover? I can give you tips if you want!
See how she shines!
oh, so fine! I'd claim those chicken wings mine and have a great time eating off some mechanics dime! OK, Fine, I'll stop with the ryme..... ing.
Sorry, got a little bored and 97SEdriver made me do it!
Old Nov 14, 2005 | 03:43 PM
Larrio's Avatar
thanks for the update. I guess I should try this on mine and hopefully the noise goes away
Matt93SE
May 24, 2019 02:58 PM
boomerbrian
Nov 8, 2015 05:10 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
kirkhilles
Aug 8, 2015 10:53 AM
