Is this soppuse to happen??
Old Nov 7, 2005 | 06:03 PM
Nickel's Avatar
I got a 96 max 5 speed.
when I drive in fist maby like 10 mph and I let go of the gas my car feels like
it want to stop. and when I put my foot back on the gas it start jumping like I when you let go of the clutch to fast
can any one give me a feed back
Old Nov 7, 2005 | 06:13 PM
DrKlop's Avatar
Driving is the next best thing
If I understand you correctly you just use your throttle too abruptly. Cars with manual transmissions are more sensitive to throttle inputs.
Old Nov 7, 2005 | 06:25 PM
Nickel's Avatar
ohhhh, so is like that. well I got another problem. I think my gas pedal be getting stuck some times.
sometimes when I'm slowing down to a spot sign I press the brakes and hold the clutch and switch it to 1st. I'm not on the gas at all and my RPM be stuck on 1 and a half for maby 5 second or on till i release the clutch
Old Nov 7, 2005 | 07:12 PM
owais's Avatar
Is it soppuse to be spelt like this?
Old Nov 8, 2005 | 09:59 AM
tavarish's Avatar
fwd gone rwd cr00
that's normal for maximas.
Old Nov 8, 2005 | 05:17 PM
Nickel's Avatar
oh, can that burn my clutch???
Old Nov 8, 2005 | 05:27 PM
Haibert88's Avatar
I have the same jerky movement when I'm in first going slow and I slowly hit the gas, so maybe that's normal...As far as going into 1st when you're stopping at a STOP sign I assume you meant, stop putting the car in 1st to stop
Old Nov 8, 2005 | 05:38 PM
LA02MAX's Avatar
as long as you have the clutch pedal depressed fully, it won't do anything to your car....
now as to the original topic, i have this as well....say, for example, i'm sitting in traffic (which i do every freaking day now because of the hurricane) and i start it out slowly in 1st gear, and fully release the clutch...now i have to leave my foot EXACTLY where it is on the throttle, because if i don't, the car will rock violently back and forth....in traffic, i usually just leave my foot BARELY touching the gas pedal so that my RPMs stay constant at around 1200 RPMs, and i'm just at a steady roll like in an automatic...now if i ever release my foot, even though it's such a small difference, the car still shakes...the same goes for if i apply any more throttle....to avoid this i have to depress the clutch before adjusting my foot on the throttle...is that normal? do my motor mounts need to be replaced?
Old Nov 8, 2005 | 06:23 PM
mcross's Avatar
I think it's just that first gear is, uh, geared like that? It's like that in all 5 spds, and max's 1st is taller than some (hondas), so the 'jerkiness' isn't too bad. If it wasn't geared like this, if you started out on a hill, it would feel like a bogging tercel. Just baby the throttle in first, or put the clutch in to coast in traffic.
Old Nov 8, 2005 | 06:39 PM
Nickel's Avatar
0k I get it now, so lets say I switch to fisrts and I put the clutch all the way down and rub the engine, wood it burn the clutch den?
Old Nov 8, 2005 | 06:40 PM
DrKlop's Avatar
I got used to it and it no longer jerks. I think that's normal for manuals
Old Nov 8, 2005 | 10:48 PM
86maxima96's Avatar
I Broke OT
that's a pretty good explanation. is this just because 1st gear is so torquey? (sp)
Old Nov 9, 2005 | 05:24 AM
crazy97's Avatar
Mine jerks all over the damn place.
SHIFT_jerk
Old Nov 9, 2005 | 10:23 AM
DrKlop's Avatar
Sort of, but I can’t come up with the better explanation. With lightened flywheel it gets even worse…
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
