FINALLY figured out why my 3.25" pulley is only giving 7.5 psi!!! WoooHooo!!!
Old Jun 4, 2001 | 06:10 PM
My 4DSC
All i got to say...."fu@kin Stillen".
The P.O.S. Bosche blowoff valve that they provide with the kit is leaking....it's bleeding off my boost!
Got a HKS Super Sequential BOV on the way.
ET bout to drop again!
Old Jun 4, 2001 | 06:15 PM
UMD_MaxSE's Avatar
Got Bent?
damn, that sucks......but at least you found the problem stupid stillen
post your new times
Old Jun 4, 2001 | 06:20 PM
Vic's Avatar
Vic
buahahaaa...i could have told you that =)
Vic
Old Jun 4, 2001 | 07:01 PM
infinitiblast's Avatar
You said is was stillens problem. No way I mean stillen is so perfect on their stuff. And cutomer service is great. If you spend even more $$$ like for a supercharger you get special reps that help you with your problems.
(The above statement is not to be copied or distribute amoung other maxima owners)
J/k
Old Jun 4, 2001 | 07:33 PM
gtr_rider's Avatar
192.168.1.1
J/k
In the Dreams of Maxima Owners. LOL
Stillen ---> <--- us
Old Jun 4, 2001 | 08:06 PM
theblue's Avatar
glad you solved it... what is your best 1/4 to date? (you're not still running the 19s are you?)
Old Jun 4, 2001 | 08:44 PM
Synki's Avatar
Good job Adam. Is that the reason why the belt keeps snapping?
Old Jun 4, 2001 | 10:03 PM
My 4DSC
No that is still a mystery...
I think it was just crappy belts (Dayco)...
We'll see how this new GoodYear works out...
I wouldn't rule out a Stillen manufacturing flaw quite yet.
I just have to correct Stillen's fu@k ups one at a time.
Old Jun 5, 2001 | 05:51 AM
So this whole time people have been saying "ah I put this pulley on there with no other fuel system mods". I'm sure you did but the reason why you had to do no fuel system mods is because of stillens shoty equipment. I'm seriously thinking about opening a company to build superchargers for cars. All I need is a good model car. I called vortech sure they supply the vortech supercharger to stillen so I can get the mounting braket and supercharger. Now I'll I need to do is make all the hosing, get the auxilary fuel pump or maybe I wont have an auliary pump and just recommend an upgraded one. Or better yet include the upgraded one in the kit. PLus I would charge less the 4,000 for this thing probably like around 3,000 or lower. Its not that expensive according to vortech the supercharger and braket go for about 650.00. Just my .02
Old Jun 5, 2001 | 06:31 AM
JJW95SC's Avatar
Oh gawd. That means mine is probably leaking also. This summer I hope to do a Blitz BOV, CAI, and pulley upgrade.
Jim
Old Jun 5, 2001 | 08:05 AM
DanNY's Avatar
Ad·min·is·tra·tor
you can generally feel the boost leaking. put your hand around the seams when you rev the engine a little. you can feel the rush of air.
Old Jun 5, 2001 | 08:29 AM
The New CLIMAX's Avatar
Very interesting info, I will be checking mine in a bit, I havebeen running about 2 PSI of BOOST, and have not found the culprit. I had a BLITZ BOV but it was letting out all the pressure into the atmosphere when ever I went from full boost to letting off the gas. the computer would not give gas, and I was stalling all the time, so I placed the Stock Bosch BOV back on and no more stalling. But I still need to check what is causing me to run 2PSI of boost. I have checked for leaks and have not found one yet, I think I need to find a better BOV I miss that sound.
Old Jun 5, 2001 | 08:57 AM
BlkCat
Is the leaking because the Bosch blow-off valve is made up of cheap plastic? I'm not sure whether to get the Blitz or the HKS BV. Which is better? I haven't taken off the BV yet but shouldn't there be some sort of gasket where it mounts to the pipe?
Old Jun 5, 2001 | 09:30 AM
1MAX2NV's Avatar
Don't you need to weld on a different flange for HKS BOV?
Old Jun 5, 2001 | 11:28 AM
skimax's Avatar
yup, hks bov has a funky flange. well if you go with any other bov other then blitz you would need to weld a new flange on.
btw, hks ssq will void vortech sc's warranty. just giving a heads up, i bought one and sold it after finding that out.
Old Jun 5, 2001 | 02:05 PM
My 4DSC
AHAHAHAHAHAHA
You actually think you have a warranty?
Trust me...you have NO WARRANTY.
Old Jun 5, 2001 | 03:34 PM
BlkCat
I thought the warranty lasted only a year from purchase date.
Old Jun 5, 2001 | 03:49 PM
My 4DSC
Stillen voids your warranty for whatever reason they see fit.
It doesnt even take changing a BOV (why on earth would that void your warranty anyway?)...
If you wanna void your warranty...just take it to the drag strip once...or change ANYTHING on the kit...
Shiet...i'm sure they'd void your warranty if you even tell them you've gotten into boost a couple times...
What warranty?
Old Jun 5, 2001 | 09:05 PM
skimax's Avatar
What warranty?
uh... did you read "STILLEN" anywhere in my post??? i said VORTECH, i do not give a rats a** about stillen. anywho, i thought screw the warranty and put the hks on but what if it really does hurt the blower(surges). then i would have to deal with MORE downtime and more stress. so i said screw it and went with something different.
Old Jun 6, 2001 | 12:34 AM
nullman
Adam, I just want to say thanks for all of the hands-on repairs and improvements you’ve done to the supercharger kit. I plan on ordering mine in July, and I will get the HKS BOV and Goodyear belt for it. You’re still using the plastic idler pulley, right? I use my car for work, driving on and off for about 6 hours a day, and I’d be paranoid about that thing breaking. Is that related to your belt breaking or not?
Old Jun 6, 2001 | 12:59 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
i also heard the same thing about using sequential BOV's for the Vortech blower. does anyone actually use the HKS with the Stillen kit? if you use an HKS and have blower probs, Stillen will send it to Vortech and if they ever find out you used a sequential then waranty would be void...
Nullman, i woudlnt recommened you put the HKS one, but if you want by all means do, let us know if you have probs.
Old Jun 6, 2001 | 07:20 AM
What is the difference b/w a sequential BOV and non sequential BOV? Why the warranty issues?
Old Jun 6, 2001 | 08:35 AM
My 4DSC
For now I'm still using the plastic idler pulley...
I'm waiting on *somebody* to get the aluminum ones made up..
<cough>phil<cough>
I'm hoping this belt will last a while but if not i'm going to give the GoodYear Gatorback a try...I have that one on order but it's gonna take 2 weeks to get...
If you get the blower DO NOT put on the shietty Dayco belt they give you....my Dayco belts have lasted between about 3 weeks & 45 seconds before falling apart.
Old Jun 6, 2001 | 08:48 AM
If you get the blower DO NOT put on the shietty Dayco belt they give you....my Dayco belts have lasted between about 3 weeks & 45 seconds before falling apart. [/B][/QUOTE]
my Dayco belt has not failed me yet, (fingers crossed) and I have been to the track a couple of times and ran about 3-5 times each time. I have even hit the rev limiter a few times But my problem is lost boost. I only have 1-2 PSI showing
Old Jun 6, 2001 | 09:03 AM
1MAX2NV's Avatar
I would not put a SC on your daily driver.
Old Jun 6, 2001 | 10:32 AM
BlkCat
Why not? I'd like to hear why.
Old Jun 6, 2001 | 11:27 AM
nullman
Well, I really want a “sleeper”, so I got the Maxima knowing that I could get the supercharger kit and have over 300hp. I use my car for my job, delivering pizzas as a matter of fact, and most of the time I drive it really easy, rarely going above 3000 rpms (I’m trying to not waste gas, too). I just want to have the power there for those “special” times, like when the road merges from 2 lanes to 1 and the person next to me thinks they can get around me. I’ll have a surprise in store for them! There are a lot of cops around here (city police, county Sheriff’s deputies, and state troopers all driving around my town), so I wanted something that wouldn’t be a cop magnet. Modifying my car is my main hobby, and the Maxima is my current project.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
02PearlSE
Feb 1, 2016 12:37 AM
cruce91
Sep 20, 2015 10:23 AM
pears
Sep 18, 2015 05:25 AM
