Rear D2 Coilover Installation help.
Old Dec 24, 2005 | 04:18 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
I am having trouble installing my rear D2 coilovers. It seems like the top hat bolts won't go into the holes on the car. It seems like the top hat is a little wide. Has anybody had this problem? I can dremel the car holes alitter wider but I don't want to do that. The fronts went on without a hitch so I think they are for the 4th gen. Any help would be great.
thanks
Old Dec 24, 2005 | 04:38 PM
Larrio's Avatar
The Definitive AE Master
I believe the rears should be the same between 4th and 5th gens. The 4th gen version of the d2's include the top hat (which may be produced wrong in this case). I believe foodmanry's front d2's couldn't fit because one of the front lower brackets were machined too narrow and couldn't fit into the knuckle.
Measure the top with with your current stock one and see if they are indeed different
Old Dec 25, 2005 | 08:05 PM
NCSU_MAX's Avatar
Maximoneypit
i had the same problem - i just gave them a little "positive reinforcement" and they eventually popped in. however i wouldnt force them to much if you can see that some dremeling would help.
Old Dec 26, 2005 | 10:42 PM
Iilac's Avatar
They are off by a few mm. Here is a quick pic that I took of them.
Old Dec 27, 2005 | 05:34 AM
njmaxseltd's Avatar
That stud on the left on the top hat looks slightly angled outward.
Old Dec 27, 2005 | 06:52 AM
foodmanry's Avatar
Da Roller Coaster!
See if you can align the stud on the left first. Like Tom said it looks angled outward. If it still does not fit correctly notify the person you purchased them from. It is possible there is an issue with it at the fabrication process.
Old Dec 27, 2005 | 06:57 AM
MDeezy's Avatar
I thought For D2's you don't need to re-use any stock parts
Just take off stock and pop in new ones. 5th gen's need new top hats for the rears
Old Dec 27, 2005 | 11:47 AM
RA030726's Avatar
I'm nutty for Nissans
thats no good. the 5th gens dont have the studs so you must reuse the upper mount.
zdreamz32
Dec 13, 2015 09:40 PM
Huttig2009
Sep 25, 2015 03:31 PM
Maxboy23
Aug 20, 2015 09:33 AM
kirkhilles
Aug 8, 2015 10:53 AM
