my car shakes on the highway!!!!!
Old Jan 1, 2006 | 09:36 AM
1HOTMAX's Avatar
it only happens sometimes, not all the time/ it would shake like i have a flat or something.
i rotated the tires and balanced all 4 and it still doing it. any ideas what else it can be? thanks
Old Jan 1, 2006 | 09:58 AM
nismos14's Avatar
§è~® f®ÈÄk
Bearings maybe.
Old Jan 1, 2006 | 11:09 AM
4x4Max's Avatar
allignment
Old Jan 1, 2006 | 02:49 PM
maX5's Avatar
Yeah, you need to realling the wheels. I had the same problem with my 4th gen. They kept doing an allignment but not good enough. Took it to another shop and the shaking was gone.
Old Jan 1, 2006 | 03:00 PM
Kevlo911's Avatar
Kevlo for President
http://www.gsp9700.com/
Old Jan 1, 2006 | 04:56 PM
MDeezy's Avatar
alignment + bearing.
Old Jan 1, 2006 | 06:14 PM
Dillbag's Avatar
Suprise butsechs!!!
road force variation issue w/ tires, the hunter balancer can fix that, unless you have a "bad" tire.
or maybe an axle vibration?
Old Jan 1, 2006 | 08:49 PM
1HOTMAX's Avatar
but my car does not pull
it just sometimes vibrate a lot on the highway. like one tire has a flat.
Old Jan 1, 2006 | 09:15 PM
dmontzsta's Avatar
Ford Only.
It could also be a slightly bent wheel.
Old Jan 1, 2006 | 09:37 PM
1HOTMAX's Avatar
bent wheel i will feel all the time. this happens only at times 30+ mph
Old Jan 1, 2006 | 11:03 PM
ChromeSE5's Avatar
Not necessarily true. I had a bent wheel and felt it only at 65-75mph, just right in my cruising speed
Old Jan 2, 2006 | 06:02 AM
1HOTMAX's Avatar
would the balance machine not read 0 0 when i was balancing all 4 wheels if it was bent? none of the wheels looked bent when they were balancing?
Old Jan 2, 2006 | 08:01 AM
nismos14's Avatar
§è~® f®ÈÄk
Well have you had the bearings checked? Or the alignment re-done? Also have you checked to make sure all of your lugs are tight? Broken/seperated belts on the tires. Bald spots on the tires. Uneven wear, bad struts/shocks. It's something most likely in the suspension if you still feel it after rotating. Did you try swapping the front rims left to right?
Old Jan 2, 2006 | 09:19 AM
Ammi's Avatar
350 Detroit Muscle
hubcentric rings?
Old Jan 2, 2006 | 10:07 AM
pu5hkar's Avatar
wait... am in the only one on here with 20's and a little steering wheel vibration at 70ish? but not so much at 90...
i figured it was across the board, honestly i have a slight vibration not enough to ever be worried, because i maintian control. but tell me others have this same thing. the steering wheel does SHAKE..... righT?
Old Jan 2, 2006 | 10:09 PM
ChromeSE5's Avatar
I was responding to the statement:
"bent wheel i will feel all the time. this happens only at times 30+ mph"
But in regards to your wheel being bent, I doubt it since it doesn't appear to be bent when spinning on the machine.
Old Jan 2, 2006 | 10:11 PM
nismos14's Avatar
§è~® f®ÈÄk
No your rims and tires are out of balance.
98maxsel's Avatar
Bent rims could do it only at certain speeds, trust me. And if you're on aftermarket rims, you NEED hubcentric rings.
Old Jan 3, 2006 | 03:46 PM
Northern Maxima's Avatar
I had the same problem for a couple days but I'm suspecting it just had to do with snow/ice buildup as it went away when the weather warmed up.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
jhontelj
Aug 17, 2015 04:07 AM
beboski
Aug 16, 2015 05:23 PM
egali045
Aug 5, 2015 09:02 AM
