MPH Problem
Old Jan 13, 2006 | 04:04 PM
Nickel's Avatar
MPH Problem
When I stop my mph reading gose under the 0 1/2 and it feels like is going to turn off. is that a problem or is it like that??
Old Jan 13, 2006 | 04:06 PM
NmexMAX's Avatar
dot dot dot ...
Well, you're not going anywhere at that speed.. Makes sense...
Old Jan 13, 2006 | 04:09 PM
Nickel's Avatar
no like when I'm driving and come to a full stop the reading gose under 0 1/2
and move up and down
Old Jan 13, 2006 | 04:10 PM
NmexMAX's Avatar
dot dot dot ...
Well 0-1/2 mph makes perfect sense.
Old Jan 13, 2006 | 04:12 PM
Nickel's Avatar
but my head light dem and the engine sounds like is stalling
Old Jan 13, 2006 | 04:14 PM
NmexMAX's Avatar
dot dot dot ...
Are you talking about MPH, or RPM.. ? The gauge that goes to 8, or the one tht goes to 140?
Old Jan 13, 2006 | 04:15 PM
Nickel's Avatar
opps my bad is RPM
Old Jan 13, 2006 | 04:18 PM
NmexMAX's Avatar
dot dot dot ...
Any check engine lights?
Pull your ECU codes even if the light isn't on.
Old Jan 13, 2006 | 04:20 PM
Nickel's Avatar
yea the check engine lights been on ever since i bought the car the dealer told me that the 96 maxima always have the check engine lights on all the time
Old Jan 13, 2006 | 04:21 PM
NmexMAX's Avatar
dot dot dot ...
Did he tell you to jump off a bridge?
Old Jan 13, 2006 | 04:22 PM
Nickel's Avatar
lol no. how do i check for codes and how to get it fix
Old Jan 13, 2006 | 04:24 PM
NmexMAX's Avatar
dot dot dot ...
Read the 4th gen sitckys, that's what they're there for.
Old Jan 13, 2006 | 04:25 PM
Nickel's Avatar
oh 0k thanks
Old Jan 13, 2006 | 04:32 PM
s0ber's Avatar
lol..
10char..
Old Jan 13, 2006 | 04:33 PM
NYPD-Arnold's Avatar
Z
LMAO. Great thread.
Old Jan 13, 2006 | 05:12 PM
9Nails's Avatar
I had a '92 Mitsubishi that did that. Suddenly wouldn't idle so I had to drive like Barney Rubbel with both feet, one for brake and one for gas jus to get it to not die at a stop light. Mitsubishi said that I had to tune-up the car to set the idle! There wasn't an adjustment screw or anything. I also had to buy a new "idle motor control" for like $200. Cost me about $320 to get the car to idle right again! Ouch.
Old Jan 13, 2006 | 05:34 PM
getbigtony's Avatar
instead of driving like two feet, do what i did when i had an idle problem. adjust the throttle cable so it idles higher, like you're stepping on the gas. my problem was an intake leak. it was pretty small, but caused my motor to idle bad at first, then it just stalls. check for that. perhaps change ur air filter. look for vacuum leaks. basic idle causing problems
Old Jan 13, 2006 | 05:40 PM
BurnNupthaSTRTZ's Avatar
I went to autozone and had them do the free diagnostic,as i had the same problem and it came back with 6 cylinder misfire and gas cap.I bought a spark plug hoping it was a fouled plug,anyway i get home eager to put the new plug in and i check the fuel injector connector for 6 and it was loose,i pull it out and there was a freaking pebble in there keeping it from plugging in all the way.I removed the pebble and plugged it in and it ran great no more low rpm headlight or instrument panel dimming.The check engine light quit flashing and
stayed on so i figured now i have to fix the gas cap problem,but after 50 to 80 miles it completely went off.The missing and dimming only happened below
1500rpm's so i guess it was plugged in enough to push enough current to supply fuel at high rpm's.I just thought i would share this story because its pretty weird,i mean how in the hell does a small rock get in there its almost as if it had been sabotaged.This probably won't help you,but it may who knows.I just had to tell everyone about it.Oh, i also have a 96.
Old Jan 13, 2006 | 06:55 PM
KsuMax's Avatar
Cheesing away...
is your computer could be in diagnostic mode?
sctludwig
Sep 1, 2022 01:32 PM
ivorton23
Sep 26, 2015 09:47 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
jcvgn
Sep 10, 2015 08:03 PM
