What's the widest tire that can go onto a stock 15" steel rim???
Old Jun 7, 2001 | 06:54 PM
The_quorum's Avatar
What's the widest I can go? I stepped from a 205/65HR15to a 215/60VR15 April last year, they lasted 44k miles...I have to get a new set within a few weeks (almost no tread left on all 4, and 5 flat tires in a month from picking up road debris...pretty good indication they need replacing I think; damn construction around Alexandria/Springfield doesn't help either).
Will a 225/55 (H/V)R15 fit on them or will they not fit or look silly w/ excess bulge??
Old Jun 7, 2001 | 07:11 PM
metallic97gxe's Avatar
Master Will
they will fit....
195,205,215,225/50,55,60,65,R15
Old Jun 7, 2001 | 07:35 PM
mzmtg's Avatar
Minister of Silly Walks
I couldnt find any 225/55-15 tires besides some hoosier racing tires. 215/60 may be your best option
Old Jun 7, 2001 | 07:59 PM
_DRU_'s Avatar
can someone tell me what the numbers mean? this was posted before but there are too many post to look through regarding tires.
215-?
60-?
R15-wheel size
thanks
Old Jun 7, 2001 | 08:03 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
215-?
60-?
R15-wheel size
thanks
in your example the 215 is the width of the tread in MM
the 60 is the ASPECT ratio, which is the percentage of the tread that makes up the sidewall, and the 15 is the rim size.
Old Jun 7, 2001 | 08:05 PM
The_quorum's Avatar
215-?
60-?
R15-wheel size
thanks
example: "215/60HR15"
215 is the width of the tire...
60 is the ratio of the sidewall height to the width (60% as high as it is wide in this case)
"H" is the speed rating
"R" means Radial I think.
15 is the wheel size (15")
Old Jun 7, 2001 | 08:11 PM
HoJo's Avatar
I have 225/60 on the stock wheels. 225/60 will have a better selection and be closer to stock size.
Old Jun 7, 2001 | 08:23 PM
The_quorum's Avatar
That's good to know, I thought you had to step both the size and the ratio to keep the same diameter. So I would not need to get a 55 aspect ratio on a 225 to keep the speedometer/odometer accurate? A 225/60 will be the same as the stock 205/65 or my 215-60? I Just want to double check...
How do they look/handle? They don't bulge too much do they?
Old Jun 7, 2001 | 08:28 PM
HoJo's Avatar
If the tire is a V or Z rated tire it won't bulge as much as a lesser quality tire will, they look fine on the wheel.
Old Jun 7, 2001 | 08:38 PM
The_quorum's Avatar
Cool. Thanks a lot. I was looking at the tirerack.com just to research a bit, and you're right about there being more selection for the 225/60 size...and the diameter is within 1/10th's of the OE tire.
Old Jun 7, 2001 | 08:46 PM
_DRU_'s Avatar
what is the average price of a V or Z rated 225/60/R15? im goin this weekend to get some. i dont need anything fancy though. thanks
Old Jun 7, 2001 | 09:22 PM
100 bucks
spazma7ik
Jan 12, 2017 09:38 PM
BkGreen97
Apr 2, 2016 05:47 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
adamgalazka
Sep 8, 2015 01:27 PM
