2 those with a MOMO shift knob ...
Old Jun 12, 2001 | 12:44 PM
ohboiya's Avatar
Did yours screw directly into the boot (I also have a MOMO boot)?
I have the Eleganza boot ... but my **** already has a silver "bolt" that the bottom of the **** screws in2 ... I don't understand / see how I can utilize this "bolt" ... is it just a waste of a piece of metal? I like it because it says MOMO right on it ....
Old Jun 12, 2001 | 03:41 PM
Chunger's Avatar
My other car is a Hybrid
I have the Shadow but I think all MOMO ***** s/b about the same...
The MOMO does not screw onto the threaded top of the shifter... Instead, it(MOMO) is held on by 3 allen bolts/screws underneath the lower part of the MOMO ****. You also have to select and fit the proper sized rubber piece that came with the MOMO kit into the hole of the new ****.
I used wound some electical tape underneath the stock shifter boot to keep it very close to the new shift ****...
Old Jun 12, 2001 | 05:08 PM
ohboiya's Avatar
Chunger ...
do u have the Eleganza boot? Momo makes 2 universal boots ... the 1 mentioned above has threads so that the **** can bolt directly in2 it .. the 1 i originally received had a twist tie sort of thread as well as some velcro? it was weird ... I wish I had a digital camera ... ****
Old Jun 12, 2001 | 06:12 PM
sleeper's Avatar
boot
some momo boots have the threaded collar, some don't. you can use the boot collar or you could just use the cap that screws onto the ****. no biggy. personally i would use the boot collar. because it conects them together. i have the boot that uses a metal piece that attaches to the boot and the ****. if you don't like that one send it back and get another.
Old Jun 12, 2001 | 06:56 PM
Chunger's Avatar
Re: Chunger ...
I'm just using the stock shifter boot...
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
atriuum
Sep 28, 2015 01:19 PM
