data acquisition refresh rate
Old Mar 16, 2006 | 08:42 PM
ThurzNite's Avatar
I was playing around with obd-2 data acquisition on a 97 GXE. The refresh rate was slow. It'd take over a minute for each sensor to refresh. For example, I'd be idling and it would show 650 rpm. I'd hafta hold the accellerator for over a minute before the data acquisition registered 2000 rpm.
Is the slow refresh rate normal? When the unit was plugged into a 2000 SE, the refresh was very fast, quicker than once a second. What gives with the difference?
Jae
Old Mar 16, 2006 | 08:49 PM
alpinestars™'s Avatar
THIS IS...
Different ECU's give out faster data refresh rates.
I think the newer ECUs give out faster data streams.
Old Mar 16, 2006 | 09:20 PM
Matt93SE's Avatar
STFU n00b!
there's many different things going on there, but you need to monitor fewer sensors to see a quicker refresh rate.
your scanner is also a big factor on it.
I've got a couple of different scanners and one takes about 20 seconds to update a single value even if it's the only one displayed. the other scanner updates them every couple seconds when you have a screen full of data and several times per second when it's the only thing displayed.
Old Mar 16, 2006 | 09:32 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
We have slow **** ecu's.
Old Mar 16, 2006 | 10:03 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
My Auterra OBD-2 scanner (works through a palm pilot) is dog slow with "fast scan" enabled. If I disable the fast scan mode, it works a ton faster. Still not nearly as fast as the ECU on an LT1 though.
Old Mar 16, 2006 | 10:30 PM
I30tMikeD's Avatar
I get 5-6 samples per second with my PocketLogger throught the OBD-II port.
James92SE
142
Jan 2, 2024 09:23 AM
BkGreen97
Apr 2, 2016 05:47 AM
gustavison
Oct 4, 2015 06:50 PM
Gingerheadman
Oct 1, 2015 05:11 PM
Socalstillen
Sep 20, 2015 11:46 PM
