HELP QUICK HID Problem
Old Mar 21, 2006 | 03:17 PM
jreilly04's Avatar
Put an HID kit in this afternoon, did the complete install and i get no headlights, I get foglights parking lights, and turning lights when blinker comes on, But i get no HID, the ballast seem to be fine and kinda do a little humming noise when they are on, like a faint buzz, and the kit was all plug n play, No splicing wires or anything. It was an KAIXEN HID kit, 9006 kit, low beam, Please any ides to help me get some headlights.
Old Mar 21, 2006 | 04:52 PM
Zero Deuce SE's Avatar
Possibly not properly grounded.
Old Mar 21, 2006 | 04:54 PM
jreilly04's Avatar
it was all plug n play, all the plugs matched up, i didnt have to clip and splice any wires or anything, i am thinking a grounding issue as well.... i am thinking i have to splice something, but its weird everything matched up fine, 100% plug n play...
Old Mar 21, 2006 | 04:57 PM
Is there any tech support from the manufacturer or a troubleshooting chart that came with the kit?
Old Mar 21, 2006 | 05:03 PM
jreilly04's Avatar
yea, its saying i did it the way its supossed to be done, thats why i am dumbfounded why i get no headlights.
Old Mar 21, 2006 | 05:17 PM
n3985's Avatar
大陆弟弟
Make sure the AMP connectors to the bulbs are clipped in the little tab. Are both sides not working? Make sure also that the wires from the ballast to igniter are well connected.
Old Mar 21, 2006 | 05:19 PM
jreilly04's Avatar
both sides dont work, so its gotta be a ground thing,, i am going crazy...i am 99% sure everything is plugged in tight.
Old Mar 21, 2006 | 05:24 PM
n3985's Avatar
大陆弟弟
You sure you didn't connect it to the highbeams?
Old Mar 21, 2006 | 05:27 PM
jreilly04's Avatar
i think so. i tried putting the higbeams on, got no light either, if i accidently put em on the highbeams how would i know.
Old Mar 21, 2006 | 05:28 PM
n3985's Avatar
大陆弟弟
Turn on your highbeams
Old Mar 21, 2006 | 05:29 PM
jreilly04's Avatar
i did, no lights.....
Old Mar 21, 2006 | 05:30 PM
jreilly04's Avatar
Could it possibly be if the ballast touches something metal ? do u have an HID kid, this kit gave me a pad to put them on so i am assuming them dont want ballast touching metal.
Old Mar 21, 2006 | 05:36 PM
n3985's Avatar
大陆弟弟
The pad is double-sided tape so you can mount the ballasts on the chassis somewhere. It does not matter if the ballast touches metal.
Old Mar 21, 2006 | 05:38 PM
jreilly04's Avatar
hrmm.. do u have an hid kit man...
Old Mar 21, 2006 | 05:39 PM
n3985's Avatar
大陆弟弟
Yes, in my fog lights. And I've done many other HID installs on friends' cars.
Old Mar 21, 2006 | 05:41 PM
jreilly04's Avatar
hrmm, you think you got a minuete to mayby call me man...
n3985's Avatar
大陆弟弟
OK, try this: turn your key to the ON position and turn on your lights. I had to do that for my friend's A4 to get the HIDs to fire up.
jreilly04's Avatar
i dunno whaqt else to do or try
Old Mar 21, 2006 | 05:46 PM
descent's Avatar
hell, start your car and try to turn them on. otherwise, take everything off and do it all over....do one at a time and make sure one lights before you connect the second one
Old Mar 21, 2006 | 05:48 PM
jreilly04's Avatar
i knew it was too good to be true, this kit was easy, take bumper off, plug everything in, bumper back on, and they dont work
Old Mar 21, 2006 | 05:50 PM
jreilly04's Avatar
did anyone have to upgrade to bigger fuses or anything. ?????
Old Mar 21, 2006 | 05:59 PM
n3985's Avatar
大陆弟弟
Plug back in the old factory bulbs and see if they light up. If not, you blew a fuse.
Old Mar 21, 2006 | 06:01 PM
jreilly04's Avatar
tested all the fuses, they r fine, i will , i am gonna go back out into the garage n see if i can try to fix em.
Old Mar 21, 2006 | 06:02 PM
jreilly04's Avatar
ill be back online in 20 min, gotta drive home with fogs.. lighting the way.... only gotta go 5 miles
Old Mar 21, 2006 | 06:16 PM
ktranne's Avatar
NOOB
last time I tried to install my fog hid, i got the humming thing too. Found out that the bulb was bad.
Old Mar 21, 2006 | 06:20 PM
jreilly04's Avatar
both bulbs though ? its not a humming noise. just sounds like they are on or charging
Old Mar 21, 2006 | 06:51 PM
n3985's Avatar
大陆弟弟
It's normal to hear a faint buzz/humming sound from the ballast.
Old Mar 21, 2006 | 06:54 PM
Tatanko's Avatar
Bacon Lover
Only time I have ever gotten that "humming" noise with mine was when one wasn't properly grounded, and another time when I forgot to hook the base back up to a bulb once.
By humming, I mean a loud, noticeable humming, too. As n3985 said, it's normal to hear it...but not that loud.
Old Mar 21, 2006 | 07:34 PM
jreilly04's Avatar
i just got my front bumper back off, and am taking a break, then trying to fix this thing
Old Mar 21, 2006 | 08:22 PM
jreilly04's Avatar
i put stock bulb in, then put HID back in, nothing, this is pissin me off... i am going to bed ill work it out tommorrow, thanks for all the help / input//
Old Mar 22, 2006 | 03:54 AM
Tatanko's Avatar
Bacon Lover
Did stock work?
Old Mar 22, 2006 | 07:15 AM
jreilly04's Avatar
yes stock worked.
Old Mar 22, 2006 | 12:46 PM
jreilly04's Avatar
thanks for all the help and troubleshooting from everyone, my HID NOW WORKS, aha, post some pics lata.
Old Mar 22, 2006 | 01:38 PM
What did you conclude?
Old Mar 23, 2006 | 02:33 PM
n3985's Avatar
大陆弟弟
So what was the problem?
Old Mar 24, 2006 | 07:15 AM
Fido Auto's Avatar
whats the problem......
Old Mar 24, 2006 | 09:35 PM
jreilly04's Avatar
The problem was i had to clip the stock plug off and splice into the HID kit, cause for some odd reason the plugs werent working like they were supossed to, so i clipped the plugs off and used butt connectors to connect the stock wires to HID. hehe, all that crap
Old Mar 24, 2006 | 09:41 PM
jreilly04's Avatar
Old Mar 24, 2006 | 10:02 PM
ichigo_san's Avatar
Looks nice How's the cutoff?
Old Mar 26, 2006 | 01:50 PM
jreilly04's Avatar
cutoff is hot, i dont know why my pics arent showing up, my bad.
