How can a torque converter improve my performance and what does it do?
Old Jun 13, 2001 | 01:08 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Yes, I know I can find the info elsewhere, but I want your input. Will be FAQ'ed and credit will be given. Thanks!
Old Jun 13, 2001 | 04:43 PM
dmontzsta's Avatar
Ford Only.
Are you serious or joking? I thought you knew your stuff!
Old Jun 13, 2001 | 04:50 PM
Y2KevSE's Avatar
I do know my stuff, but I want others to answer. It's not fun updating the FAQ with only my input.
Old Jun 13, 2001 | 05:36 PM
UMD_MaxSE's Avatar
Got Bent?
Hey, I answered this already and you put it in the 5th gen FAQ sticky. But if you want it again....
A torque converter is basically the clutch for an automatic transmission. It transfers power from the engine to the transmission gears. However unlike a clutch in a manual transmission, the torque converter (TC) transfers power hydraulically through the transmission fluid. Since the transfer of power is done hydraulically rather than mechanically, more power is lost between the engine and drivetrain. Thus, an upgraded or stronger TC will provide a better transfer of power to the drivetrain. You will not be gaining any horsepower, rather you will be recovering horsepower that would have been normally lost with your stock TC. In addition, a stronger TC will have a higher stall speed. This will allow better launches when you are brake torquing or flashing the TC. In other words, you can bring the revs up higher when you launch with a TC that has a higher stall speed.
please correct me if any information is incorrect
Old Jun 13, 2001 | 05:39 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
amen...nice write-up
Old Jun 13, 2001 | 05:46 PM
Y2KevSE's Avatar
Copy/paste is the best.
Old Jun 13, 2001 | 05:47 PM
UMD_MaxSE's Avatar
Got Bent?
tanks
Chris91SE's Avatar
Eagles Fan 4 Lyfe
no need to reinvent the wheel
Old Jun 13, 2001 | 05:49 PM
Y2KevSE's Avatar
Bump
Old Jun 13, 2001 | 08:36 PM
Dave B's Avatar
Not DAVEB the parts guy
Actually there are a few things wrong here
An upgraded stall converter will be stronger IF you get a stronger unit. However, most quality aftermarket torque converters that increase stall speed are stronger internally. Raising stall speed has nothing to do with strength. You don't gain back hp either. Actually you loose even more power at the expense of the added stall speed (ie more slip before stall speed is achieved). What you get in return is much better torque multiplication which is what makes for stronger launches at WOT.
Dave
Old Jun 13, 2001 | 11:47 PM
bigtexan7's Avatar
what Dave said. My understanding is that they only allow you to launch at higher rpms which is only beneficial if you have slicks or drag radials. On regular tires, you'd only spin worse. But that's just my understanding. I don't actually have one.
Old Jun 14, 2001 | 05:13 AM
UMD_MaxSE's Avatar
Got Bent?
Dave
thanks for the clarification...
Old Jun 14, 2001 | 07:20 AM
The_quorum's Avatar
Just wondering about this...
What would raising the viscosity of the Auto tranny fluid do?
Old Jun 14, 2001 | 07:22 AM
infinitiblast's Avatar
yes
Old Jun 14, 2001 | 07:32 AM
sleeper's Avatar
converter
this is the "street" explanation. if you have upgraded your automatic transmission and put in a high stall converter, you can launch like a rocket. this can be an advantage especially when your engine is not that responsive, through mid range torque.
Old Jun 14, 2001 | 01:07 PM
Y2KevSE's Avatar
Any other input?
Old Jun 14, 2001 | 01:40 PM
UMD_MaxSE's Avatar
Got Bent?
NO
Old Jul 26, 2018 | 12:17 PM
rablaze93's Avatar
Does a torque converter work differently for a CVT than an auto?
topdog1207
Oct 21, 2003 08:59 AM
DMan_2KMax
Nov 5, 2002 01:42 PM
gryps
Nov 16, 2001 12:09 PM
cartman702
Jul 19, 2001 05:01 PM
greddymax
Apr 19, 2001 05:42 AM
