Nismo wheels
Old May 30, 2006 | 08:22 PM
kajeno's Avatar
Nismo wheels
I asked in the wheels forum, but need answer asap as I need to purchase them on 5/31 in the am. The rims are 18x8.5 with 45 offset and only weigh 17.6 lbs each. I will be mounting 235-40-18 tires on them. The set will go on a 97 with an eibach drop (1.5). Do you forsee any rubbing issues? Looking at my 16 inch oem set, it looks like I am ok. Please let me know asap.
Old May 31, 2006 | 01:18 AM
A33 VQ30DEK's Avatar
no rubbing gurantee.. especially with a 235-40-18, you could run 245-40-18 if you wanted to.
Old May 31, 2006 | 04:58 AM
MorpheusZero's Avatar
My wheels are 16*8.5 +35 with 245/45 rubber and I rubbed the splash guard so bad it almost cracked in two.
Old May 31, 2006 | 05:27 AM
wikidminds's Avatar
post pixs after install.
Old May 31, 2006 | 05:31 AM
kajeno's Avatar
Does anyone has 8.5 width rims with 45 offset on his/her 4th gen?
Old May 31, 2006 | 09:10 AM
MDeezy's Avatar
if for some reason they rub a spacer should solve it. I'd still go ahead and buy them. that some light **** 18's
Old May 31, 2006 | 12:19 PM
vsamoylov
i have a 8.5 inch rim offset 42 and no rubbing. tire size is 255/35/18
Old Jun 5, 2006 | 01:42 PM
Lawtown's Avatar
I have 18x8.5" rims with a 45 offset (no lip) wrapped with 235/40/18 and the only rubbing I get is when I cut the wheel all the way and hold it while turning. I'm dropped with Progress springs (F 1.75)(R 1.5). I think rim design may play a factor but I think you should be all set.
Old Jun 5, 2006 | 03:32 PM
Conrad283's Avatar
I need a truck
Sweet wheels. Got pics?
Old Jun 9, 2006 | 11:40 PM
ACEEMaxima's Avatar
No rubbing...I have 19x8.5" in the front with tein stechs with a +40 offset..and no rubbing whats so ever
Mar 12, 2020 12:06 AM
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
ToTheMax305
Sep 23, 2015 09:11 PM
dcam0326
Sep 8, 2015 11:02 PM
