Gawd-awful scraping noise after replacing the cat hanger bracket.
Old Jun 20, 2001 | 07:21 PM
JJW95SC's Avatar
After the dealer replaced the bracket, I drive away and immediately notice a horrible rattle/scrape that I've never heard before. It is inconistent and shows up sometimes at around 2k rpms, turning seems to cause it as does stomping the pedal. Revving while parked does NOT cause it though.
I bring it back and they throw it back up on the lift. We pushed and thumped but could not reproduce the sound on the lift. They didn't really want to deal with me but I argued since I'm an old guy and they eventually refunded the labor potion of the repair ($80) which is more than I expected.
Now, it could be the Stillen y-pipe scraping the section of frame that runs along near it. It's also been suggested to me that it is related to the motor mounts.
Any other ideas or things I should check?
Jim
Old Jun 21, 2001 | 05:48 AM
95Max's Avatar
Jim,
I have the same problem when I had my Y-pipe put on. The b-pipe was hitting the car. Take the a rubber exhaust hanger like the ones that hold on the muffer and put it inside the hanger for the b-pipe. This will keep the b-pipe down thus not hitting the car and the noise is gone.
Old Jun 21, 2001 | 09:49 AM
BlkCat
Have either of you replaced the "S" pipe that comes before the resonator with a straight pipe? I did it on the recommendation of another member and I'm finding the exhaust bumping into the heat shields whenever I drive down my bumpy back lane. I grit my teeth each time it happens!
Will that rubber exhaust hanger help me in this case?
Daniel.
Black '98 SE auto/V2 SC/B&M Supercooler/Courtesy FSTB & clear corners/Koni Sports/Eibach Pro Kit/PIAA Superwhites/Obx brushed aluminum pedals
Coming soon: Don's VB Mod
Old Jun 21, 2001 | 10:47 AM
Dave B's Avatar
Not DAVEB the parts guy
Daniel.
I takes a bit of adjusting to make the straight pipe work between the B-pipe and cat. What I had to do was drop the pipe and bend the shields up and out of the way. If I hit a big bump and the B-pipe is hit and expanded and can hear it sometimes.
Dave
Old Jun 21, 2001 | 11:01 AM
Dave B's Avatar
This might be a long shot, but right after installing my y-pipe, I got this strange rattle/buzz from 2000-2200 that only occured underload that seemed to be coming from underneath the glovebox. I couldn't figure out for the longest time and I figured it was the y-pipe torqueing against the frame. Months later I was working under the hood and I saw that the AC line and bracket that runs along the passenger side of the engine compartment was rubbing underneath side of my FSTB. I simply bent the bracket down and the noise went away. Somehow, when I installed my Y-pipe something got moved around. You might want to check this. This was happened on lots of 4th gens.
Dave
Old Jun 21, 2001 | 12:44 PM
BlkCat
Thanks, Dave
I'll try bending the shields to make clearance...
Old Jun 21, 2001 | 02:37 PM
JJW95SC's Avatar
Originally posted by 95Max
Jim,
95Max,
Do you have a pic? I'm not sure what you mean by 'inside the hanger for the b-pipe. I have a Greddy cat-back exhaust...if this makes a difference.
Jim
Old Jun 22, 2001 | 07:45 AM
95Max's Avatar
Jim,
I have seem your monster so I know that you have the Greddy. BTW you sill owe me a ride. Yes I know the deal you will get a ride in the Z.
I would think that since the Greddy is a direct fit, it would use the same hangers as stock. Look under the car toward the back end of the b-pipe. There should be a hanger that is oval. What you want to do is zip tie another inside that hanger thus preventing it from compressing keeping the b from hitting the underside.
Chris
Old Jun 22, 2001 | 02:37 PM
JJW95SC's Avatar
Jim,
Chris
Oh, I didn't know you were 'that' Chris. I'll take a look and see if that helps. Thanks for the info!
Jim
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
May 24, 2019 02:58 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Starrider
Sep 17, 2015 07:26 AM
