engine trouble- please help
Old Jul 12, 2006 | 09:33 AM
specialmax's Avatar
I just put a new engine in my Nissan. Everything is together, all fluids in, everything hooked back up. One problem- engine will not start. When you turn the key, the starter goes and goes, but engine will not turn over. After about 5 seconds, the battery fades, and after a while, it will not even attempt to start. I took the battery to Autozone and had it charged back up. Same thing happened.
Things I have noticed:
-battery seems to fade VERY quickly. Battery test at Autozone showed good battery
-When I open the gas cap (as if to add gasoline) no escaping hiss sounds.
Any input would be helpful.
Old Jul 12, 2006 | 01:54 PM
njmaxseltd's Avatar
You say the engine "will not turn over". Do you mean the starter isn't turning it or do you mean the engine is cranking, but not starting???? Please clear that up so we may better assist you.
Old Jul 12, 2006 | 03:44 PM
Machinist's Avatar
2 basic things to check for 1)spark 2)gas.....
Old Jul 18, 2006 | 04:03 AM
jspec11's Avatar
Yes, Machinist knows what he's talking about.. check those two things.
Also, if your "new" motor is used.. your fuel injectors might be rusted/clogged. Try using the original ones if you still have them.
Old Jul 22, 2006 | 07:09 PM
hotair231's Avatar
Check for spark. Take a spark plug out, connect the wire and ground the plug to the engine. Turn the engine over to see if you have spark. If you don't have spark it could be a bad crank sensor.
Old Jul 22, 2006 | 07:20 PM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
hook the batt to a charger so it doesnt die for one. Also an engine needs three thigns to run: fuel, spark, air. Check em all
Old Jul 25, 2006 | 09:51 AM
Mints33's Avatar
Speaking of batteries, what kind (wet, gel, or agm) of battery is stock on a 2000? Mine died, for I was away on vacation for 2 months. Plus what amp are these rated at, I have a charger, which does 2,10 and 25 amps.
Old Jul 25, 2006 | 01:25 PM
ThurzNite's Avatar
I'm going to check the FSM, but I'm pretty sure it says not to use this method to check for spark.
Jae
Old Jul 26, 2006 | 06:41 PM
kinzer1's Avatar
don't know what to say, good luck
Old Jul 28, 2006 | 05:53 AM
12vVR6's Avatar
Jae
Whats the reasoning behind this??
I've used that method for everycar i've ever worked on including bijangxe's max... Didnt hurt anything
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
