GXE & SE suspension comparison!?
Old Jun 25, 2001 | 09:07 AM
RayRey21's Avatar
Does anyone know what exactly the difference is between the two?? I know the SE has the sport tuned suspension but what does that consist of exactly?? "i.e...springs, struts etc...." Also, is it possible to put a sport tuned suspension in a GXE?
Thanx
Old Jun 25, 2001 | 12:28 PM
mzmtg's Avatar
Minister of Silly Walks
Slightly firmer struts and springs. It wouldnt be worth the $$ to put an OEM SE suspension into a GXE. You'd be much better off buying aftermarket stuff.
Old Jun 26, 2001 | 04:02 AM
wdave's Avatar
The SE also has stiffer front lower control arm bushings - that's probably a cheap upgrade. The 00 SE also had additional braces in the radiator cowl area but these seem to have disappeared by 01 - easy to make.
wdave
Old Jun 26, 2001 | 08:58 AM
ToYLeT902's Avatar
JET Speed Lab
my SE suspension feels so mushy, go with eibach's, im doing that once i get the funds
Old Jun 26, 2001 | 12:14 PM
BlancMax's Avatar
had a 95 SE, now have 96 GLE
I've driven both the 4th gen SE & GLE (same suspension as GXE?) and there is only a slight difference, but that might be caused by the crappy tires on the GLE I'm driving now.
Old Jun 26, 2001 | 12:21 PM
Sprint's Avatar
who cares.. everyone changes them anyway eventually
Old Jun 26, 2001 | 05:18 PM
LoveSick's Avatar
Re: had a 95 SE, now have 96 GLE
I have owned both before too. I owned a 96 GXE and now a 2K SE with differential. The SE definetly handled much better than GXE. The GXE shocks loses its life very easily, it became so soft that I got rid of the it and purchased the 2K SE instead. The SE uses Tokico struts.
GXE do not have the same suspension as GLE. If you look at the Catalogue, GLE has the so called "luxury" suspension.
Old Jun 26, 2001 | 05:47 PM
ToYLeT902's Avatar
JET Speed Lab
Re: Re: had a 95 SE, now have 96 GLE
so does that mean i can just get the eibach pro kit and not have to get new struts to match?
Old Jun 26, 2001 | 09:23 PM
LoveSick's Avatar
Re: Re: Re: had a 95 SE, now have 96 GLE
Although the stock SE comes equipped with sport tuned tokico struts, it still has comfort in mind over performance. They do not perform as well as the after market tokico. But sure, you can use Eibach on them, but I think its worth getting new shocks as well.
My friend used Tokico performance struts with stock SE springs and it is still very agressive.
Old Jun 26, 2001 | 09:26 PM
AznWontonboy's Avatar
umm they use macpherson struts.. not tokico.. unless its different up in canda, which i highly doubt. by the way, a 4th gen and 5th gen are different. so comparing the 2 in 2 different classes doesnt work
Old Jun 27, 2001 | 03:55 AM
wdave's Avatar
Mcpherson is the type - named after a Ford of England engineer in the 60's. Tokico is one of many manufacturers of Mcpherson struts.
wdave
Old Jun 27, 2001 | 04:12 AM
ToYLeT902's Avatar
JET Speed Lab
wdave
i learn something new everyday
Old Jun 27, 2001 | 06:36 AM
Sonic's Avatar
I actually laughed after reading that. Sorry, AZN.
Old Jun 27, 2001 | 08:09 AM
Dave B's Avatar
Not DAVEB the parts guy
Don't worry about the small differences in suspension between models. The aftermarket setups are MUCH better handlers and little ride quality is compromised if you do it right. I've pretty much removed everything from my car that makes it a SE. I've changed out the whole suspension (Koni, KYB, ST springs) and added different wheels. All I've got to seperate my car from a GXE is a sunroof and Bose.
Dave
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
