Scraping noise coming from wheels when turning. Nissans says its my pads.
Old Sep 11, 2006 | 01:22 PM
Killah Kane's Avatar
So I took my car to nissan today for some work, one was that when I turn very slow, I hear a low scraping noise from my front wheels. They told me that is because I have aftermarket pads on and that using nissan pads will correct the noise (I dont know what kind of aftermarket pads are on currently). What you guys think? Is this true or BS? Anyone had this noise before?
Old Sep 11, 2006 | 02:55 PM
Dubbya's Avatar
VK56 Inside
Could be a dust shield rubbing on something, or a shim hitting the rotor.
Old Sep 11, 2006 | 03:09 PM
irish44j's Avatar
retired moderator
sounds like dust shield to me....what pads do you have?
Old Oct 4, 2006 | 08:59 PM
Henryhta1's Avatar
Are the rims new and you have just installed them on your Maxima? If they are, they probably had wrong offset. If the rims are not the case, check the brake-calibers if they are stuck.
Old Oct 5, 2006 | 10:10 AM
VIP Maxima
aftermarket pads. what BS. something is rubbing against something. check under there ! are you lowered with big wheels? maybe ur rubbing !
Old Oct 11, 2006 | 02:19 AM
Eyemfaster's Avatar
i had a similar problem when one of my front pads was completly worn away, and it started grinding the rotor, especially when i would go in reverse slowly with the wheels turned. i'd say have a brake shop check it out. and as soon as possible. my rotor is trash now.
Old Oct 11, 2006 | 06:07 AM
NCSU_MAX's Avatar
Maximoneypit
BS on it being aftermarket pads. I agree with the previous posts
Old Oct 2, 2007 | 05:56 PM
hose's Avatar
I have the same noise (when turning while moving slow). I took my 2005 Maxima SL to the dealer to have them diagnose the noise. The dealer said it was the front pads, so I had them put on new genuine Nissan replacement pads. The noise is still there. I'm planning on making another appointment with the dealer to have them look at it again.
Old Oct 2, 2007 | 08:33 PM
irish44j's Avatar
retired moderator
I can't believe you people can't check your own pad thickness!!!!!!!!
oh, and moving to general discussion.
Hondarydr
Dec 30, 2024 06:15 PM
homeyclaus
Sep 3, 2015 06:15 PM
kirkhilles
Aug 8, 2015 10:53 AM
follyburr
Aug 7, 2015 09:50 PM
MikesChevelle
Aug 7, 2015 05:57 PM
