Throw out bearing or input shaft bearing noise? Which is it?
Old Sep 29, 2006 | 10:43 AM
95maxrider's Avatar
Lightly modded
Recently I've noticed that I'm getting a noise from my tranny. At first I thought it was my TO bearing, but after talking to some people, it sounds like it may be the input shaft bearing going bad.
If the car is in neutral, I get a slight chattering, but when I push on the clutch the noise goes away. From what I understand, this is the opposite of what happens when your TO bearing goes bad. Can anybody verify this?
The tranny is a rebuilt unit from Phoenix Reman. Trannies I bought on Ebay 3 years ago. The TO bearing is a OEM unit I had installed with my Spec stage 2 about a year or two ago. I've heard of people who buy reman trannies and the shafts aren't shimmed properly, so after 15,000-20,000 miles, the input shaft goes bad. Since I've put on about 20,000 miles on this tranny, it makes me wonder if this really is my problem.
Any tips or advice would be appreciated. Thanks.
Old Sep 29, 2006 | 11:42 AM
nadir_s's Avatar
vicodin ... gift of life
i had the same issue ... it was the TO bearing for me that came w/ my exedy clutch
Old Sep 29, 2006 | 02:51 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds like the input shaft bearing to me....T/O bearing tend to make noise when the clutch is pushed in...
Old Sep 30, 2006 | 09:10 AM
95maxrider's Avatar
Lightly modded
anybody else?
Old Sep 30, 2006 | 03:33 PM
Ceasars Chariot's Avatar
Old Maxima Legend
nealoc187 can help you sounds like input shaft bearing, i have the same thing and i have the exedy stage 1 clutch, push the clutch in while in the neutral car is silent, release and i hear this hissing kinda spinning noise? hope i can make it through another drag racing season?
links
http://www.motorvate.ca/mvp.php/801
http://forums.maxima.org/showthread....58751&t=473007
http://forums.maxima.org/showthread.php?t=432379
Old Sep 30, 2006 | 04:58 PM
GoalieKeg's Avatar
anybody else?
It's definitely the input shaft bearing. Make sure whoever replaces it reshims the tranny correctly, or else it's going to fail again on you prematurely.
Old Oct 3, 2006 | 03:30 PM
VQ30DETT's Avatar
i had the same problem, it was the input shaft bearings
Old Oct 3, 2006 | 05:08 PM
RA030726's Avatar
I'm nutty for Nissans
Ditto... been there, it was the ISB not the TOB.
Old Oct 3, 2006 | 05:45 PM
machiniac_g's Avatar
it is the T.O. bearing which is causing your noise .if it was the shaft bearing then you would have atarns failure a long time ago
Old Oct 10, 2006 | 12:00 PM
Nealoc187's Avatar
SLOW
Don't listen to this guy because he doesn't know what he's talking about.
edit: looks like you found my thread 95maxrider, good. hopefully it will help others too.
Old Oct 10, 2006 | 05:44 PM
95maxrider's Avatar
Lightly modded
Yes, your thread sealed the deal. New tranny is in and feeling great
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
Andy29
Sep 29, 2015 05:32 AM
