getting my car back!
Old Oct 16, 2006 | 05:35 AM
maxmumsxspd's Avatar
yea so i am finally getting my car back with my new headlights and fixed up bumper and all today at 3pm...finally getting my hands back on my sweet sweet 6 speed...and ordered clear corners/polargs for daytimes, reverse, and clear corners...NICE. will post pix of car with dad's SLR camera this weekend
Old Oct 16, 2006 | 10:20 AM
**EDIT**just talked to my autobody guy and he said nope not getting the car today. he said there is a problem with the window on drivers side that they replaced...when you use auto-up feature it goes up then drops 2-3inches back down. nice. i told him to have it done by wednesday...we'll see if that happens. not too pleased. DAMNIT.
Old Oct 16, 2006 | 11:30 AM
Hoooper
haha, i love the good news of getting car back, i just heard that im likely to get mine back soon if it starts, possibly done this week.
Old Oct 16, 2006 | 11:33 AM
A33 VQ30DEK's Avatar
is your car still at the shop - san bruno?
Old Oct 16, 2006 | 11:40 AM
owais's Avatar
the same thing happens to my driver side window..i wonder why.
Old Oct 16, 2006 | 12:03 PM
djfrestyl's Avatar
Suspension Yoda
There is a reset procedure using the red button inside the door.
Old Oct 16, 2006 | 12:05 PM
djfrestyl's Avatar
Suspension Yoda
Good ol search funtion. Here you go fellas
_______________
Your Window Regulator needs to be reset, here is the procedure posted by another member:
Driver window one touch up RESET procedure - TIP!!
With the help of the technical service manual on CD produced by Nissan on the 2002 and 2003 Maxima I now have located the quick fix for a problem I have had since purchasing my used 2002 SE a few months ago. That is the drivers door window one-touch up function for the window was not working properly. The window would go up to the top and then retreat about 5 inches back down again. This problem is due to the limit switch needing to be reset which at first I thought would be a considerable job (to take off the door panel etc.) but ended up being literally a 2 minute job as the door panel can remain in place. My dealer wanted $85 CDN for the switch reset which I knew was a rip off before I found the fix procedure myself. I know several '02 and '03 Maxima owners have had this same problem as I saw earlier threads referencing it but no-one then appeared to know the fix. Alhough this procedure is simple once you do it, my description seems long as I wanted to be a descriptive as possible since I can't provide pictures. So here it is:
Step 1: Pry the plastic cap up off the bottom centre of the door pull handle and remove the single philips screw.
Step 2: Remove the whole switch panel (in which the door pull handle sits) by prying it up from the back end either with a flat edged screwdriver or table knife (under cloth) or by hand which is what I did. It is just clipped in so should come out relatively easily sliding it up at the back and then pulling it back.
You can now see the inside of the door from where the switch finishing plate sat. You can leave the wiring all attached and simply hang the switch and handle plastic assembly to one side so you can see the inside of the door.
Look inside towards the front bottom of the door behind the plastic vapour barrier you will see a small black switch. It almost looks like a black pan screw head. This is the reset switch but there is a sequence to now doing the actual reset procedure. The switch doesn't really feel like one when you press it through the plastic liner which incidentally you don't need to cut (at least I didn't have to). It is a switch that is only on when you are pressing it otherwise when released it is off.
STEP 3: Make sure the window is closed (up) completely. Turn the ignition on so the windows are receiving power.
a) Press the reset switch (and keep it pressed in) and open (down) the window completely (manually -NOT with AUTO ONE TOUCH DOWN FUNCTION).
b) Release the reset switch. Then close the window completely (manually only - NOT AUTO UP).
c) The limit switch is now reset. Easy!!!
This procedure worked for me straight away as I hope it will for you should you have this annoying problem. The Nissan manual does caution you not to use the one touch UP-DOWN function during this procedure so be warned.
Old Oct 16, 2006 | 06:05 PM
Hoooper
yes it is, hopefully home soon
Old Oct 16, 2006 | 06:19 PM
NmexMAX's Avatar
dot dot dot ...
In the shop for the swap,??? And if so, when will ET be phone home?
Old Oct 16, 2006 | 08:15 PM
Hoooper
i have no idea, got the harness in today, maybe tomorrow. still have to swap out the harness. if that works it should be done...possibly end of week, more likely next week
Lakersallday24
Jun 16, 2019 01:35 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
maxima297
Aug 3, 2015 12:50 PM
