what's Knock Sensor?
Old Jul 2, 2001 | 12:04 PM
NJGuy
The check engine light is ON, and when I had it check they found it's because of the KNOCK sensor, any1 know what is it and what is it used for?
thanx
Old Jul 2, 2001 | 12:14 PM
Jeff92se's Avatar
I'm needing a caw
It's a sensor that senses knock. Sheesh!
Old Jul 2, 2001 | 12:18 PM
mzmtg's Avatar
Minister of Silly Walks
It's a small sensor located down in the "V" of the engine below the intake manifold. It mounts to the block. It's there to "listen" for predetonation, aka "knock", aka "pinging." This means that the fuel/air mixture is exploding before the spark plug can properly ignite it. This explosion (as opposed to the desired controlled burn) can quickly destroy valves, spark plugs, piston rings...and stuff. Knock is generally caused by high combustion chamber temps which are caused by too much spark advance or an overly lean fuel mixture. When it senses knock, it retards the timing to get rid of it...
Old Jul 2, 2001 | 02:09 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Forum search results for "Knock Sensor"
http://forums.maxima.org/search.php?...der=descending
NJGuy,
Your post wasn't real specific......do you want to know how to fix it? Do you remember the ECU code you were given?, etc.....
Look in the ECU Diagnostic Code "sticky" post in the 4th generation forum, where you will find details on the knock sensor, code 0304, and the search results in the link above....
Old Jul 2, 2001 | 02:20 PM
mzmtg's Avatar
DAMN! Even after I go ahead and answer the guy's question Bill decides he needs to b!tch about searching.
Old Jul 2, 2001 | 02:24 PM
bill99gxe's Avatar
I didn't b!tch....I just pointed to how/where to get more info.......The post seemed REAL generalized.....
Not trying to downplay your explanation.....
Old Jul 2, 2001 | 02:26 PM
mzmtg's Avatar
thanx
That's the question I tried to answer. Seemed specific to me...
Old Jul 2, 2001 | 02:34 PM
bill99gxe's Avatar
Just recognizing the pattern.....the next ? is usually "Can I fix it?" then "How much will it be?" then "How do I reset the ECU?" then "Why the hell am I being told to search?" and then "I hate bill99gxe"........I was just trying to stop the endless pattern...
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
