3.5 VQ's blowing up...some additional information
Old Jan 18, 2007 | 02:22 PM
97SEdriver's Avatar
this place is dead
I got an email from a buddy who's G35 engine blew up within 11,000mi. Anyone else heard this explanation?
At least my engine lasted through the first
oil change without a death rattle. The service guy told me that Infinity
instructed them to tell new owners to be more aggressive with the engine
during the break-in period than the owner's manual says. There seems to be
a link between drivers going easy for the first 2000 miles and certain seals
never seating correctly.
Old Jan 18, 2007 | 02:44 PM
LA02MAX's Avatar
during break-in, you should drive in a fairly aggressive manner. Using heavy throttle inputs pushes the rings out which makes them seat quicker. Another thing you should make sure to do is constantly check the oil. Had he done that, his engine would not have died already. Also use dino oil at first, not synthetic.
Old Jan 18, 2007 | 04:08 PM
Zog's Avatar
Zog
That's horsesh1t. Most newer performance cars ship from the factory with mobil1 in them. If the people that built the engine think it's fine from the factory, I'm inclined to believe them. Everything I've read has stated the same.
Old Jan 18, 2007 | 04:46 PM
MaximaGT-R's Avatar
I'm a Happy Man!
WoW that serious
Old Jan 18, 2007 | 05:48 PM
LA02MAX's Avatar
Most "performance" cars you are talking about have extensive engine break-in procedures before the engine is even put into the car...most normal manufacturers (ie: nissan) do very little break-in on their engines, therefore the rings are not seated properly when they appear on the showroom floor. When the rings aren't seated properly, dino oil is optimal because it has a higher viscosity (it varies) than synthetic....I'm not saying synthetic is going to blow your engine up or anything, but it is better for break-in to use dino oil...
Old Jan 18, 2007 | 07:01 PM
tarpoon's Avatar
My 04 came with the dino oil, both nissan and infiniti grease monkeys say that is the preferred oil for that engine
Old Jan 18, 2007 | 08:19 PM
NmexMAX's Avatar
dot dot dot ...
Dude can't even spell Infiniti correctly and he has one
My idler pulley flew off, but the engine is still intact and hasn't gotten thirsty. 5 years, 3 months old, 81.5k, sees 7000 RPM daily.
IBthenyouwonderwhyyourpulleyfliesoff
Old Jan 18, 2007 | 08:21 PM
2LEET4U's Avatar
maybe someone put gasoline in with his oil???? hehheeh brings back old memories....
Old Jan 19, 2007 | 07:23 AM
nismo_star's Avatar
I have pending oil consumption issue with my fx35 currently, burning 1.5qt/mo. I avg about 1000-1500mi /mo. being documented every 1st Sat of every month, for the last 5 months to see if it gets worse.
Old Jan 19, 2007 | 08:19 AM
clayman88's Avatar
I understand checking your oil is important, but why is it necessary to check it so frequently on a brand new car? Are they more likely to leak? Just wondering what the reasoning is.
Old Jan 19, 2007 | 08:29 AM
jcalabria's Avatar
NINE-time Maxima Owner
At least two related reasons:
  • Its likely to burn some oil early-on, since rings haven't seated yet.
  • Being new, you have no idea what its pattern of consumption is, so checking often is the best way to both learn what that pattern is and to prevent it from getting too low.
Old Jan 19, 2007 | 05:05 PM
Zack342's Avatar
good to know because that is what is was Very agressive.
Old Jan 19, 2007 | 05:13 PM
HotshotVQ35's Avatar
got my 02 brand new...ran dino oil till 10K went synthetic after, no burning or losing...
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
