Short throw shifter
Old Jul 5, 2001 | 12:09 PM
delio's Avatar
OK I am about to install the Short throw shifter that I got months and months ago, since I will be installing my new Y pipe, RT Cat and Catback... My question... What position do I want the ball in for best shifts... I hear that most people like it at 2/3 of the way in one direction, which is that... Also which kind of lubricant do I need for the Shifter install? Lithium? If so what kind... Any other tips b4 install... This if for an SMC by the way.
Thanks,
Del
Old Jul 5, 2001 | 12:16 PM
Sprint's Avatar
it came with lubricant
Old Jul 5, 2001 | 12:40 PM
ejj's Avatar
ejj
Thanks,
Del
Most people will tell you that 2/3's (1/3 short of the shortest setting) is a good setting.
I installed mine set to the shortest setting. I had to put a sizable dent in the heat shield above the cat, but it worked just fine.
Like Sprint said, the lubricant came with the kit, but I don't remember it being anything special.
Old Jul 5, 2001 | 12:47 PM
delio's Avatar
OK which way is the shortest?
It is probably really obvious if you look at the thing, but I have not looked at mine in months so it is not apparent in my mind. I bought back when Russ had that huge GD... prolly around the holidays. Crazy...I gotta dig it out of my closet.
Old Jul 5, 2001 | 12:53 PM
ejj's Avatar
ejj
Re: OK which way is the shortest?
The higher the ball (higher being closer to where the shift **** screws on) the shorter the throw.
Old Jul 5, 2001 | 01:05 PM
delio's Avatar
thanks for the info man...
This should be fun. :-)
Old Jul 5, 2001 | 01:23 PM
ejj's Avatar
ejj
Re: thanks for the info man...
No problem. Good luck!
Old Jul 5, 2001 | 01:36 PM
The New CLIMAX's Avatar
Re: Re: thanks for the info man...
The lithium is for the STS, not for you to use for personal use lol
Old Jul 5, 2001 | 08:12 PM
CKNY's Avatar
I had the hardest time installing my sts (ask sprint... i must have AIM'd him every 20 minutes).... but that was because I couldn't for the life of me get the cat off. Since you're replacing all that you should have no problem. Install the shift ball at the shortest setting, I love it, and that's all the way up the shaft. The other thing is that you're gonna need a hell of a dent in that heat shield if it's all the way short. I couldn't bang it out as much as was needed because I had to slide the heat shield over the cat so I bang on the heat shield a little sometimes but otherwise I love it... Good Luck del.
PS - I couldn't find the lub that came with mine either, turns out it's white bicycle grease that you can pick up at a bike store. Home Depot may have something similar.
Chris
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
maxinout93
Oct 31, 2015 02:04 AM
atriuum
Sep 28, 2015 01:19 PM
