VSS...Auto - 5 Speed Swap...HELP
I got all wiring taken care of. I have everything taken off the Auto tranny and I have a couple questions. What do I do with this sensor? (shown below)
![](http://i70.photobucket.com/albums/i109/MattLee02/DSC02181.jpg)
![](http://i70.photobucket.com/albums/i109/MattLee02/DSC02180.jpg)
and what does it plug into on the manual tranny or what do I have to wire from this sensor to make everything work like its supposed to??
Thanks,
Matt
Thanks,
Matt
So.....no one can answer this question and give me a hand?? I mean even if its that easy please just let me know...at least then Ill know I was overlooking something simple and making it hella complicated....
![](https://maxima.org/forums/images/smilies/support.gif)
Originally Posted by 2k1maxgle
I find this hard to believe...out of all the people on the .org that has done this swap....not a single person can help me???
I already answered your question 3 hours ago in one of the other three identical threads that you have on the go.
Originally Posted by eng92
What exactly are you looking for?
Im looking for a SURE answer, not a maybe or something for the 4th gen....Ive learned throughout this swap that its different between the 2. Enough to where Hal's write up is only good for what to do when. Wiring is different, pedal install is different, pretty much everything is different, including this speed sensor deal.....
Yes, I have an A32 chassis. However, my engine, ecu, gauge cluster and all the associated wiring for those items are from an A33B (02/03 maxima)
Specifically, my wiring for the speed sensor had to duplicate what is used in an 00/01 with TCS. This was a requirement because the speed signal on an 02/03 comes from the ABS module which I do not have.
If you have indeed looked at and understand the wiring diagrams in the FSMs for A32 and A33, what I have told you in your other thread in the all motor forum should be obvious.
Specifically, my wiring for the speed sensor had to duplicate what is used in an 00/01 without TCS. This was a requirement because the speed signal on an 02/03 comes from the ABS/TCS module which I do not have.
i'm pretty sure that sensor goes into the tranny. Isn't that the Park Neutral sensor. I could be wrong sorry.
If you said something about the speed sensor... our speed sensors is with the abs sensor. No speed sensor in the transmission
It's the speed sensor. I've had to replace mine because the plastic plug on it broke during my engine swap. I don't believe you need it for the manual tranny. try unplugging it and seeing if you get a CEL.
I just realized, I had the TCS/no-TCS configurations transposed in my post in your all-motor thread.
It is the vehicles without TCS that get the speed signal from the ABS control module. You are in the clear.
Although wiring the sensor as I suggested would have worked fine, it would have meant some unecessary wiring.
That connector connected to the AT VSS (pictured above) can be left unused as it is just wired back to the TCM, which is no longer in use. The VSS sensor on the manual tranny does not need to be connected to anything.
My apologies for the confusion.
Originally Posted by A33 VQ30DEK
it's not the speed sensor. The speed sensor is along with abs sensor.
maybe i'm thinking of something else, because when i was doing my swap, turbo95max was trying to figure out where the speed sensor was and we found out that the speed sensor was located with the ABS sensor.
knight_yyz
11-01-2015 01:34 PM
