Need Help replacing rear brake pads!!!
Old Jul 9, 2001 | 05:04 PM
Blade_99SE's Avatar
I'm trying to install my new brake pads and rotors. I was able to replace the rotor but I can't seem to compress the rear calipar piston. I tried useing a C clamp but it's not working. BTW I didn't have any problems changing the front rotor/pads.
Does any one know how to compress the rear drivers side calipar?
Thanks in advance
Blade
Old Jul 9, 2001 | 05:07 PM
ejj's Avatar
ejj
Thanks in advance
Blade
You need to screw the caliper in using a set of pliers or something similar. Using a c-clamp will only fight that screw.
Old Jul 9, 2001 | 05:30 PM
Ravq's Avatar
You have to turn the pistons clockwise while pushing them in. They make a special tool for the job which I think runs about $10 but regular needle nose pliers do the trick. It only took 3 or 4 turns when I did it. Here is the tool in case you're interested:
KD #3163 Disk Brake Piston Tool
http://www.mytoolstore.com/kd/kdbrak07.html#3163
(Credit goes to Daniel B. Martin for providing this part in another thread)
Old Jul 9, 2001 | 07:30 PM
Blade_99SE's Avatar
Thanks, the pliers trick worked fine. What a pain though. Silly Nissan tricks are for kids, but now I know and that's half the battle. YO JOE !!!!!!
Blade
Old Jul 9, 2001 | 07:35 PM
Ravq's Avatar
Blade
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
