injectors and fuel rails!
Old Oct 18, 2000 | 05:01 PM
tclee's Avatar
anyone here tweaked / changed their injectors / fuel rails? I would like to know what injectors to get?! the 300zxTT? 5th gen fuel rail?
has anyone here reground cams? was thinking of getting a set from a junk yard and sending them to crower for regrinds...any thoughts?
for my 4th gen!
Old Oct 18, 2000 | 10:59 PM
Southpaw17
i know bull frog makes cams for maximas there like 700 beans.
DEBO
Old Oct 19, 2000 | 12:39 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
i heard the 5th gen fuel rail should bolt up to the 4th gen.
im gonna be using 370cc injectors from RC enginnering. 370 come stock on the 300ZX TT. I have custom cams on my motor that im building but i dont know the specs offhand right now.
Old Oct 19, 2000 | 04:45 AM
Confused's Avatar
Permanent Maxima.org Resident
I30KRAB put some 300z injectors on his
infiniti,, where is he?
Old Oct 19, 2000 | 04:47 AM
Shingles's Avatar
The missing moderator
Unless you have a supercharger on your car or some heavy mods, just changing injectors does absolutely nothing. Stock injectors provide more than enough fuel.
-Shing
Old Oct 19, 2000 | 05:41 AM
The New CLIMAX's Avatar
You will also have to get your ECU upgraded by
JWT or someone else. The 370 CC injectors on a 300ZX TT Stock work fine, I also believe they are the same injectors as the Infiniti Q45, for the 300Z you must find them from 94+ if I am not mistaken, the 90-93 will not work as a direct bolt on so to speak, But Shingles is right unless you have an S/C, Turbo's or Running the Laughing Gas, then there really is no reason, it would be a waste of money, The stock injectors are good for ~260 HP.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
cruce91
Sep 20, 2015 10:23 AM
