rear window just fell down in door in '95 max?
Old Apr 23, 2007 | 03:54 PM
slicey's Avatar
i searched the forums and all i could find were motor and/or regulator type discussions. Like, broken motor or regulator issues. This is not my problem, however. Was wandering if anyone here could shed some light on what my problem might be. door switch operates motor quite well. I can feel a cable that exits a cable-housing at the base of that "center" track, in which the cable then runs up the back of that track, moving up and down via the window switch. I thought, maybe that cable might have disconnected from something and that's why the window fell down into the door? Can anyone give my a clue before i have to continue removing any more parts to figure out what the hecks going on, PLEASE? I appreciate any help. thanks
Old Apr 23, 2007 | 04:07 PM
SR20DEN's Avatar
VQ Wizard
You need to reassemble the regulator. The regulator cable is no longer attached to the window lift and your cable is now a big mess inside the spool box.
It's a real PITA to fix.
Old Apr 23, 2007 | 06:29 PM
killerVQ30DE's Avatar
Put me on the list with this issue - whos got walk through instructions for this?
Old Apr 23, 2007 | 06:55 PM
slicey's Avatar
ahhhh, sthhanku veerry much!
Old Apr 23, 2007 | 07:08 PM
chillin014's Avatar
i'd just buy a new regulator, they arent that expensive.
not hard to install either, you gotta take off your door panel and eye ball the whole situation. its easy to figure out once you take a look at all of it...the window has to be raised to certain heights so you can stick your wrench through a hole in the frame. take the glass out, and then take out the regulator.
just eyeball it, thats how i got it.
Old Apr 23, 2007 | 07:21 PM
slicey's Avatar
thats not going to happen. i'm poor, as in, i sleep in my car.
Old Apr 24, 2007 | 07:57 AM
mms's Avatar
mms
Same thing happened to mine. I opened up my door panel to check it out. Messed with it for about an hour and then just jammed something in it to keep the window from falling into the door again. I have 220k miles and figured it’s not worth spending money on fixing it.
Old Apr 24, 2007 | 08:12 AM
SR20DEN's Avatar
VQ Wizard
I have fixed two of these and have never had to spend money on them.
Old Apr 29, 2007 | 01:18 PM
Sounds like the go then.. I'll pop the panel and see.
Old Dec 4, 2011 | 12:32 AM
ShocknAwe's Avatar
yes pop off the panel, the rear panel is easy to get off. Run the switch and see if the actual frame goes up or not. If it doea then it a simple fix of putting the window itself back on the frame.
Old Dec 4, 2011 | 09:22 AM
T_Behr904's Avatar
stevesmax
Dec 17, 2020 11:57 AM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
mpbclutch33
Aug 21, 2015 06:09 AM
doctorpullit
Aug 20, 2015 05:15 PM
