neep help with APC wire harness
Old Jul 12, 2001 | 04:49 PM
styLINmax's Avatar
okay, i followed chestons how-to instructions....but my headlights still wont turn on. Theres just a clicking sound when i turn the light off and on. help?
Old Jul 12, 2001 | 08:46 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
do the high beams work?
Old Jul 12, 2001 | 11:35 PM
styLINmax's Avatar
um...not sure, i uninstalled the harness already. I will try installing again in the morning. could the high beams be a factor on why the light insnt working?
Old Jul 12, 2001 | 11:44 PM
styLINmax's Avatar
Old Jul 12, 2001 | 11:45 PM
Chebosto's Avatar
RIceD OuT moDErAtor
the clicking means that the relays are working..
did u try making sure your bulbs work correctly? besure to GROUND the harness too
dont forget that.
--cheston
Old Jul 13, 2001 | 04:22 AM
Ramius83
Yes, as Cheston said, make SURE that the relay is grounded. When I have installed foglights on my friends three cars, each time we had problems with grounding the relay switch. Make sure that it is a GOOD SOLID connection. Good luck.
Old Jul 13, 2001 | 05:35 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
dont forget that.
--cheston
hmmmm.... i've installed a couple of these bad boys and 2 of them had this issue. The highs worked and the low's didn't but the relay still clicked. Swapped out the relay and it was fine...
Old Jul 13, 2001 | 10:42 PM
styLINmax's Avatar
it works!
it works now. yea, the problem was that the harness wasnt properly grounded. thanks you guys for your help!
doctorpullit
Mar 29, 2016 11:08 AM
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
