o2 sensor stripped!!
Old May 21, 2007 | 05:51 PM
Majestic's Avatar
Yahhhhhhh
Well I was trying to replace my o2 sensor today and the o2 sensor socket stripped the o2 sensor so now I have no clue how to get it off. Any ideas? or has this happened to anyone?
Old May 21, 2007 | 06:21 PM
Wassup2114's Avatar
Vice grips?
Old May 21, 2007 | 06:22 PM
bwinter7's Avatar
I'm sure that PB blaster is out of the question already. I would get a torch, heat it up and hope to god a pair of vice-grips does it. That's my best answer
Old May 22, 2007 | 07:52 AM
Majestic's Avatar
Yahhhhhhh
any other ideas?
Old May 22, 2007 | 08:09 AM
KRRZ350's Avatar
Drive the car around first, or use a torch, heat is your best freind, then vise-grips, just get them so incredibly tight that you can barely clamp them shut, that's the only solution, even if you have to take the y-pipe out you still will need to use a large pair of vise-grips.
Old May 22, 2007 | 09:05 AM
Majestic's Avatar
Yahhhhhhh
it was semi-hot when i tried it so maybe it should be hotter
Old May 22, 2007 | 11:29 AM
bwinter7's Avatar
Definately, if PB doesnt do it, then get it really-really hot and vice-grip it, if that doesnt do it, your screwed my friend!
Old May 22, 2007 | 02:33 PM
KRRZ350's Avatar
if that doesn't do it, just pull the y-pipe, will be much easier.
Old May 22, 2007 | 08:13 PM
Torgus's Avatar
if you stripped it you pulled when you should have pushed. the only way to fix it is have a new bung welded in. buy a new 02 sensor while your at it.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
