Traction control/ ABS need help
Old Jul 29, 2007 | 09:43 PM
i30ish's Avatar
My “TCS off” and “ABS” lights are on. Well, the go on and off at random times. For example sometimes when I come to a complete stop, they both go off, sometimes they don’t. Sometimes they just blink as I’m driving, other times they disappear for a while. They come on and off together, never separate. The car drives fine. I have a 2000 i30, with 121 K. Thanks in advance.
Old Jul 30, 2007 | 05:33 PM
NmexMAX's Avatar
dot dot dot ...
My guess is an ABS sensor is on its way out.
Old Jul 30, 2007 | 06:50 PM
MacGarnicle's Avatar
when the lights are on, try to pull a code... if nothing comes up, most likely the sensor.
Old Jul 30, 2007 | 08:41 PM
slinky87's Avatar
uh have you checked your brake fluid level? thats usually the cause of ABS lights coming on
Old Jul 30, 2007 | 09:04 PM
NmexMAX's Avatar
dot dot dot ...
uhhh
That's another wrong assumption/misconception.
Fluid level &/or ebrake not fully disengaged is the BRAKE light, not the ABS light.
ABS light is typically an ABS sensor, especially when coupled with the TCS light.
Old Jul 31, 2007 | 08:21 AM
i30ish's Avatar
thanks. fluid is fine and that's the first thing i checked. the lights are not on anymore, but maybe rain had to do something with it, so maybe it is a sensor.....
Old Jul 31, 2007 | 08:30 AM
NmexMAX's Avatar
dot dot dot ...
For obvious reasons, rain or any other low traction weather situation would cause them to turn on.
Old Jul 31, 2007 | 08:43 AM
i30ish's Avatar
no, i meant rain was responsible for incorrect reading or glitch in system or something. i've looked through parts online, looks like i need rear right and left.
Old Jul 31, 2007 | 08:49 AM
NmexMAX's Avatar
dot dot dot ...
Rain was responsible because of low traction issues, is that what you meant? Rain = more 'slick' than dry ground. In this case, you would not need the sensors since they're only doing their job. But if they turn on intermittently,then that would mean a problem with the sensor(s) itself.
So, you've verified that you need 2 rear sensors? How did you verify? Was it through an ABS code reader?
bbsitum
Sep 6, 2019 07:31 PM
leatherneck
Sep 30, 2015 09:16 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Djsmaxima
Sep 14, 2015 11:58 PM
maximusrising
Sep 2, 2015 09:55 AM
