Decal Alignment
Old Jul 30, 2007 | 12:13 PM
mannetti21's Avatar
Decal Alignment
Anyone have an easy way of aligning the Maxima.org decal in the rear side windows so that its level? The "eyeballing it" method isn't quite cutting it for me....not much of a surpise to me considering it takes some real effort for me to fold a piece of paper perfectly in half
Old Jul 30, 2007 | 12:48 PM
Max_Out's Avatar
Under the radar
I just used eyeball and my two pinkie fingers under it and presto came out great.
Old Jul 30, 2007 | 11:10 PM
lunchbox's Avatar
T-Square and a China marker. The marker will wipe off the glass easily and the line will be straight.
Old Jul 31, 2007 | 12:27 AM
spdfreak's Avatar
You should be able to place a piese of masking tape on the window and align it till it's at the angle you desire.
Then plase the sticker alongside it.
I didn't make myself very clear, but you should get the idea.
Old Jul 31, 2007 | 02:17 PM
SilverGLE's Avatar
I'm watching you, boy...
You could try a laser level, as well...
Old Jul 31, 2007 | 03:02 PM
erty67's Avatar
Decal Specialist
if need be, trim the transfer tape around the decal with a pair of sissors.
Old Jul 31, 2007 | 03:03 PM
erty67's Avatar
Decal Specialist
option #2: drive to RI and I'll put it on for ya.
Old Jul 31, 2007 | 03:12 PM
RA030726's Avatar
I'm nutty for Nissans
Put a drop of dish soap in a spray bottle full of water. Spray the window and sticker really well, move the graphic around till its perfect, then squeegee the water out.
Old Jul 31, 2007 | 03:17 PM
erty67's Avatar
Decal Specialist
you could do this too, but Joy is one of the only dish soaps that won't wear on the adhesive. Baby shampoo works too. Make sure it's completely dry before you pull the transfer tape off.
Old Jul 31, 2007 | 04:58 PM
spdfreak's Avatar
Can someoe post exact instructions on how touse the "joy" soap method?
Old Jul 31, 2007 | 07:17 PM
erty67's Avatar
Decal Specialist
honestly, I would suggest doing it dry. The wet method may actually be tough as the decal's so small. This site has two pretty good ways of lining it up using a piece of tape to do a dry install. Look on the bottom of the page where the "top hinge" and "center hinge" methods are described.
http://www.fastdecals.com/decal_installation.htm
wet...
For a wet install simply spray down the the installation surface (usually the window) using a spray bottle filled with water and a VERY small amount of liquid soap. Also spray down the backside of the decal you are installing as you remove the paper backing. Now position the decal where you want it withOUT applying pressure. Once it is aligned use a squeegee or equivalent to remove all the water. After you have allowed the decal to dry (a heat gun or hair dryer speeds up the process) remove the application tape.
Old Jul 31, 2007 | 08:28 PM
machinehead131's Avatar
just stick on there.
Old Aug 1, 2007 | 12:46 PM
RA030726's Avatar
true, last time laying on tint I used baby shampoo. i kinda felt dumb buying it too, just for a drop none the less.
Apr 16, 2020 05:15 AM
05RLS2
Nov 7, 2016 05:52 PM
06maxima55
Sep 28, 2015 04:29 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
