black corners
Old Aug 19, 2007 | 01:54 AM
max ride 41's Avatar
black corners
yo, anyone know where to find the black corner lights to match my headlights?? they only have them for 97 and up on e-bay, i don't know where to look. links please....
Old Aug 19, 2007 | 08:46 AM
99grnmaxgxe's Avatar
You could try opening them up and painting them.
Old Aug 19, 2007 | 09:28 AM
max95q's Avatar
I painted mine. It wasnt hard. I used some high temp low gloss black engine paint. See sig.. Im going to get some 97-99's and paint them the same way. Since I have new headlights, and I AE'd those as well, everything looks good except the corners. I even AE'd the fogs. Those were the hardest to do.
Old Aug 19, 2007 | 11:04 AM
markd248's Avatar
They should be the same things between 95-99. The 4th gen corners weren't different, just buy the ones on ebay or look in the 4th gen classifieds.
Old Aug 19, 2007 | 12:30 PM
will black corners from a 97 work?? i'm assuming they will??? i saw a set on e-bay and they said only fit 97 to 99"s???
Old Aug 19, 2007 | 08:15 PM
markd248's Avatar
As I said, yeah they'll work. All the corners on 4th gens (95-99) are the same. So just buy the ones on ebay that you saw.
Old Aug 20, 2007 | 12:58 AM
I thought so, why would they be any different...... here are the ones i bought off e-bay 75.00, they look pretty nice.
Old Aug 20, 2007 | 06:27 PM
markd248's Avatar
Yeah you can also keep your eyes peeled in the 4th gen classifieds section. You could get a used one for cheaper or get 1 piece headlights (cefiros) for a little more.
Old Aug 20, 2007 | 06:45 PM
Dave H.'s Avatar
They will fit fine, but you will have to use the stock wiring harness with them. The harness is different between 95/96 and 97-99. Other than that, no troubles, I've bought them on ebay as well. If the price is $75, that is a little much. I think I paid around $40. Keep looking, also check procarparts.com.
Old Aug 21, 2007 | 05:36 AM
well, you try and find the black corners like i got, they're hard to find and i got tired of looking for them elsewhere. the other 1's i found were completly black or fogged, and somebody said paint them. i'm not painting them plus the rubber seal is peeling away from the edges. so, i'm glad i got them, even though the dealer said their was a production date difference from 95-96 to 97-99. they said they will fit.
Old Aug 21, 2007 | 06:44 PM
max95q's Avatar
They fit the same but the 97-99's have clearer plastic lens' stock than the 95-96's do.
Old Aug 23, 2007 | 04:02 PM
WildMax87's Avatar
why are you going to the dealer to install aftermarket parts?
Old Aug 24, 2007 | 07:46 PM
i did'nt go to dealer, i went to my buddy, who's a tech and he put them on in 2 seconds. no charge and the harness as you'll notice had to be removed to make the new harness plug up. i only have a pic of old harness and lights, i'll post a pic tomorrow of the lights.
Old Aug 25, 2007 | 12:23 PM
depoautolights
personally i would suggest getting the one piece smoked cefiro headlights...better yet you can get the 2 piece glass smoked cefiro headlights (or just the corners by themselves) let me know if this helps.
Old Aug 25, 2007 | 01:17 PM
thanks man, but i'm done with the headlights and corners for now. my only problem is the headlights are dirty inside the lens and don't match the new black corners i got. any way to clean them???
Old Aug 25, 2007 | 03:29 PM
depoautolights
its kinda hard...but you may have to loosen the clips to take the light apart...i have some maxima headlights, what year is yours? i can give you the clips that hold the lens to the housing if you mess up yours while trying to clean it...again i wont recommend this though unless you have taken some headlights apart before...
Old Aug 25, 2007 | 06:54 PM
nope, i have'nt done that before. i was thinkin you could spray chandalier cleaner into the lights and they would drip dry inside the lens. only problem is gettin the excess cleaner out of the bottom of the lens. any way to clean them while still together???
REDinLV
Aug 15, 2024 12:30 AM
BobTX10
Oct 7, 2015 08:43 AM
Redfox
Sep 28, 2015 10:41 AM
