*doh* Fuel problems with sc?
Old Jul 22, 2001 | 12:07 AM
Chebosto's Avatar
RIceD OuT moDErAtor
for those with the v2: hehe. time for me askin the questions:
1) when driving after boosting or pressing the gas, and i let it off, i press the gas, again, and the car lags alot. the rpms maintain stay and i keep flooring it.. nothing happens, then all of a sudden the fuel i guess comes back on then the car boosts like mad. im wondering if its the aux fuel pump? i have it rigged on full time (i think) so curious what it might be.
2) do you think it could be the BOV is not releasing enough pressure and that there is buildup, slowing the turbine down?
3) thanks much. i'll be taking it back to the shop for the clutch/flywheel install in a few days. just wanted to ask first so i know what might be up.
--Cheston
Old Jul 22, 2001 | 12:25 AM
BrianV's Avatar
After I put the UPRD chip in I noticed that when I floor it sometimes in first gear the engine gets louder but I don't get any power and then about 1/2 second later it kicks in hard. I think it's my clutch, but I could be wrong. Of course I'm not S/c and I'm sure our problems are unrelated. However, you stated your clutch isn't installed yet, so that might be it. I know mines near the end of its life and you said yours was too.
I doubt it's the BOV. On the supercharger I don't think excess buildup will make a off to sudden on feeling. Also, if you're not getting a substantial amount of fuel the car would probably feel more like it's surging.
Wait to see if your clutch helps to solve the problem.
Good luck, other than that how's the S/c?
Old Jul 22, 2001 | 12:27 AM
emax02's Avatar
--Cheston
A few question for you. What exactly do you meen you have the fuel pump rigged up full time? Is that opposed to having a on/off switch from the fuel relay to the aux. fuel pump?
Also are you using the Blitz BOV I sold with the kit? If not what kind are you using?{Curius}.
Last ???, did you do a custom CAI? What kind of material is the CAI piping made out off? If you used a rubber pipe{Like my dumba$$} for the CAI it may be sucking it's self together and blocking airflow.
Ok, now possible problems. Your fuel pump relay may have been damaged from the new wiring. You should also check to and make sure the wires connected to the fuel pump are on properly. As for the BOV, I don't think that will affect reving very much, but I may very well be wrong.
What I whould do is put your car in 3rd at say 30 MPH and slowly rev the car up until 5-6.5K RPM's. This way you can rule out some possible problems.
Old Jul 22, 2001 | 12:28 AM
irvine78's Avatar
--Cheston
you took the car out without the new clutch and flywheel? hehe...someone was in a hurry....hehehe..
how do you like it?
Old Jul 22, 2001 | 02:21 AM
OgreDave's Avatar
in a hurry? he was hurtin everyday!
Old Jul 22, 2001 | 07:17 AM
MardiGrasMax's Avatar
I know that feelin
Old Jul 22, 2001 | 08:41 AM
got rice?'s Avatar
what type of fuel pressure regulator?
Old Jul 22, 2001 | 05:21 PM
nizmolee's Avatar
everybody wants a test drive when its done.. good luck and have fun maxus 2001
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
cruce91
Sep 20, 2015 10:23 AM
bumpypickle
Sep 20, 2015 08:22 AM
conansriver
Sep 11, 2015 10:26 AM
