who makes high flow oil filters?
Old Oct 22, 2000 | 06:54 PM
VQracer's Avatar
i think i saw this somewhere but i forgot where.
Old Oct 22, 2000 | 07:11 PM
VQdriver's Avatar
K&N makes a pretty trick filter. they also have that filter relocation kit that also adds more oil capacity to the car.
Old Oct 23, 2000 | 12:40 PM
Lordrandall's Avatar
AMSOIL makes nice oil filters.
[Edited by Lordrandall on 10-23-2000 at 03:03 PM]
Old Oct 23, 2000 | 02:37 PM
justinmc's Avatar
Some may think its stupid but I use
K&N exclusively... their "gold" series filters.. alot of parts stores carry em (I work at Advance and we have a whole shelf full of em.. I know my VG part # is HP-2008.. not sure on VQ's).. I went and grabbed one of mine out the garage.. of interest to you the stuff on the box says..
1" nut for removal (this is a really nice feature .. hand tighten.. then when you go to take it off just slip a 1" socket on it and back it off ...)
provides over 550PSI hydrostatic burst strength
anti drainback valve (like that reccomended by nissan for use on the max's)
lowest pressure drop flows 12-16GPM
10-20 Micron Filter
over 150,000 pressure impluse fatigue cycles (2.5 times more durable than other filters)
90% efficient (more than any other filter)
UNAFFECTED BY RACING FUELS
I went with em the first time I saw em because I knew what they did for air filters... after seeing the anti-drainback valve feature and the 1" nut I was sold.. really nicely made too.. they feel "sturdy" not cheap like frams, purolators, etc...
Old Oct 23, 2000 | 02:48 PM
MAXDriver
Yep, I'm pretty impressed with KN oil filter. I've bought 1 dozen for my Integras but STILL LOOKING H-A-A-A-RD for the VQ oil filter. If you have VQ part #, please help.
Just curious, is there a difference in VE and VQ engine oil filter ?
Old Oct 23, 2000 | 02:56 PM
Jeff92se's Avatar
I'm needing a caw
You STILL have that one??? : )
10-20 Micron Filter
Old Oct 23, 2000 | 08:31 PM
Erik G's Avatar
I know that this is overkill but I use Canton Racing filters
It is an machined aluminum body powder coated(heavy duty) that accepts cartirdge style filters. Filters down to 8 microns with an anti drain back valve. I use this with redline oil. The filter was like 80 bucks and the replacement filters are about 6 check it out at http://www.cantonracing.com/spin-on.cfm#specs
Old Oct 24, 2000 | 09:53 AM
Here's a website to check out
This site has some good info on filter brands and construction matters. They also try to determine which filters are made by which manufacturer.
Like anything else, take it FWIW:
http://members.nbci.com/minimopar/oilfilterstudy.html
Mobil 1, Pure One and the K&N's seem to be favorites.
Jurassik
Old Oct 24, 2000 | 10:32 AM
justinmc's Avatar
Re: You STILL have that one??? : )
Re: You STILL have that one??? : )............ Jeff why actually no.. I have a couple that I keep spare on hand.. I actually used "that one" last oil change.. its on there now .. hehe. (I ended up with a couple extra).. either way.. filtering away .. hehe
MatthewsMaxima
Sep 11, 2015 03:21 AM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
