anybody know anything about compression tests?
Originally posted by Biomax
what type of results do i get? do i get each cyllinder's pressure? are they all supposed to be pretty close? how close? what are good pressures (does it depend on engine size, etc?)
thx
Robert
thx
Robert
You doing this to the maxima or you new secrete car? If you are doing it secrete car, must be a pre-owned vehical eh?
-Shing
Do you suspect bad rings? Why compression test?
-Shing
[/I][/QUOTE]
-Shing
he...he...he...
nope
not secret...discussed it yesterday...
yes...a rare and beautiful (and quick) 1995 MR2 Turbo
-Shing
he...he...he...
nope
-Shing
nope, it's in pretty good shape
hell as good or better than my 97 actually...guy is real honest (so far) but car is in virginia and i want to be real picky before i fly out there to put some cash on this sucka.
plus he's selling for 2k less than i usually see them for (which means he's only asking $500 over Blue book while everyone else asks 2500$ over)
Robert
Robert
Most car manufacturers want all cylinder compression to be within about 10% of each other.
For example: Nissan's 96 Maxima manual says to expect 185psi with an accepted minimum of 142psi and a difference of 14psi max.
Standard practice is to try pouring a small amount of engine oil in each cylinder through the spark plug hole to help the rings seal and try again if a cylinder is low to see if the compression jumps. If it does for a cylinder then you've got a possibility of bad rings. If it doesn't then possibly a bad valve. If two adjacent cylinders show low after the oil test, then a bad head gasket is possible, though it could still be valves in those two.
Mark
Mark
tarun900
19
12-20-2021 06:57 PM
knight_yyz
11-01-2015 01:34 PM
DC_Juggernaut
09-28-2015 04:07 PM
