car leaking oil (slowly)
Old Aug 19, 2001 | 06:34 PM
costcowholesale's Avatar
I changed oil a couple weeks ago and every other day I see like 1ml of oil on the floor, its coming from the drain plug, it is fully tighten, but the problem is it didn't have a gasket on it (losted), is that why its leaking? can I seal the plug till the next oil change without taking the plug out? or is my plug damaged?
Old Aug 19, 2001 | 08:14 PM
emax02's Avatar
It sure sounds like your plug is causing the problem. Just get a new plug.
Old Aug 19, 2001 | 08:19 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
if it's that little of oil just try some high temp sealant that comes off easily. or if you don't have mobil1 just change you oil and get a new plug. filter is ok.
Old Aug 19, 2001 | 08:49 PM
I'm running castrol syntec right now for 4000km, the oil is not always leaning, just once in a while, I'll get a new drain plug, do you have any idea what it costs?? I think nissan dealers will charge me like $500 for it
thanks
Old Aug 19, 2001 | 08:57 PM
I'm running castrol syntec right now for 4000km, the oil is not always leaking, just once in a while, I'll get a new drain plug, do you have any idea what it costs?? I think nissan dealers will charge me like $500 for it
thanks
Old Aug 19, 2001 | 09:24 PM
emax02's Avatar
It should only cost about $10.
Old Aug 19, 2001 | 09:29 PM
TarHeelMax's Avatar
Good news, Costco, http://www.courtesyparts.com/A32_maint.html has your drain plug for $1.99 and those copper crush rings for $0.79 each.
Old Aug 20, 2001 | 07:14 AM
there you go costco, 3 bucks plus shipping. i might replace mine next oil change just because.
Old Aug 20, 2001 | 03:12 PM
I'm screwed
OH MAN I'm the biggest idiot on earth some a$$hole stole my oil dip stick when changing car's oil then I decided to change my own oil this summer so I drained the oil, put 4 liters of oil in and then I CHECKED THE TRANMISSION OIL DIP STICK when I think was the engien dip stick, it looked alright so I packed everything up. Then after like a month I started seeing oil spots everywhere int eh garage, checked it out today and the oil filter was lose, then I tighten it back and checked oil (which really is tranmission) and it was the same so I looked @ the manual and realized that someone STOLE MY ENGINE DIP STICK and the reading is incorrect, worst part is I drove to detroit for a trip last week (1000km) with the leaking that I just found out.
Old Aug 20, 2001 | 04:15 PM
Re: I'm screwed
haha, kinda funny. you should have put in 4.5 quarts too.
Old Aug 20, 2001 | 04:22 PM
Re: Re: I'm screwed
what I want to know is did I damaged my engine? I've ran that engine pretty hard this month too
carguy96
20
Feb 6, 2021 06:21 AM
Lakersallday24
Jun 16, 2019 01:35 AM
egali045
Aug 16, 2015 01:19 PM
acw
Aug 13, 2015 12:50 AM
acw
Aug 7, 2015 04:20 PM
