Question about fluid levels (power steering and radiator)
I was checking out my fluids the other day and noticed that the power steering fluid is at the 'cold min' line. My radiator expansion tank is only a couple cm above the min line.
I never really paid attention to the levels in the past year, but they shouldn't be that low, right? I'm thinking I should add some.
Does anyone recommend any particula PS fluid and radiator fluid ?
No recommended PS fluid, but remember, you can use tranny fluid in the PS system no problem. If you don't have an obvious leak, I would check the hoses on both, and then just fill it. As for antifreeze, use good old Prestone, in a 50/50 antifreeze/water mix. Some loss is acceptable.
CorollaULEV
30
Aug 9, 2021 08:11 PM
vingodine
45
May 21, 2016 12:46 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
