CAI or Pop Charger?
Old Aug 27, 2001 | 11:48 PM
black019's Avatar
I was wondering which is better. I've heard different opinions but I wanted to what the popular opinion is. I plan on getting a y-pipe, cat, and exhaust at some point and I heard that cai is needed to fully take advantage of the additional bolt ons. maybe i heard wrong. please inform me!
Old Aug 27, 2001 | 11:55 PM
BriGuyMax's Avatar
I'm only going to say this once becuase it has been discussed literally a MILLION times.
CAI advatage: a little better low end, I've yet to have my buddy with the same mods as me except CAI beat me out of a light.
POPcharger advantage: much better high end. I run my buddy with his CAI and me with my pop...and we have the EXACT same mods on '97 5-speed SEs and I always pull up top.
the CAI sounds a little cooler, but the pop will take just as much advantage of your other mods for a much smaller bill
Old Aug 28, 2001 | 12:02 AM
Sonic's Avatar
If you want to drill a hole in your car, get the CAI, otherwise, get the Popcharger. Simple as that. Oh, and this has been discussed to DEATH!! Try searching, it should show more than 50 posts about this.
Old Aug 28, 2001 | 12:58 AM
black019's Avatar
ive tried the search function and it never turns anything up
Old Aug 28, 2001 | 01:57 AM
DaEnigma's Avatar
I have had a lot of trouble with the search function also...
But IMHO the CAI is the way to go, but the differences are negligible.
CAI= Good low to upper midrange power
SI/JWT= Good topend power
I feel that the CAI is better due to the fact that I use the low to upper midrange a lot more then the topend...
Also I feel in stop and go traffic the CAI has an advantage due to the under hood temps climbing quickly...
But like I said before this is all IMHO...
Old Aug 28, 2001 | 09:02 AM
PhatGuy
If your car is an Auto go with the CAI. If you drive in a winter environment or if it rains a lot you might want to get a bypass valve for CAI.
If you drive a 5spd and you launch at 3500rpm or above you really won't see too much loss of power on the low end. I myself have the Pop charger style and have created a custom 4" tubing that routes under my splash guard that will blow cooler air directly on the filter as the car is in motion.
Old Aug 28, 2001 | 02:46 PM
djslinkyz's Avatar
that's really cool how'd you do that?
Old Aug 28, 2001 | 03:49 PM
PhatGuy
I took a 4" in diameter tube (durable rain drain type tube) and I first cut a lip on one end. I then tied the lip end of the tube to the splash guard with the tube facing forward with the lip (to help induce air) about an intch or so below the splash guard. I then routed the tube up on a slight angle (don't really have a choice) to blow directly on the Cone filter. I tied the the part of the tube by the filter to a bracket that the old intake was attached to. There is no question that while my car is moving that there is cooler air being blown directly on the filter keeping it cooler especially since the tube is 4" in diameter. The faster the car is going the more cooler air being blown on the filter and surronding area. Total cost about $3.00.
Old Aug 29, 2001 | 12:23 AM
black019's Avatar
oh yeah i didnt mention that I have an auto. didnt know that had an effect. so cai is better if I have an auto?
Old Aug 29, 2001 | 02:00 AM
TurDz's Avatar
Think of it like this.
With an auto, especially during daily driving, you don't rev your car all the way to redline, all the time (hopefully, heee). Most of your power is in the 1K-4000RPM range. This range is optimal for CAI. CAI gives you a bigger torque "kick", while w/ a Pop Charger, you feel a loss in that "kick." You feel more gains with the cone intake at 3500RPM to redline, where you hear that "growl."
I'm trying to guess why it works like this though. You would think that a Pop Charger can take in more air from a stand still, but it doesn't. I think that tubing (that leads to the throttle body) creates a vaccum effect, which gives you that floaty feeling of torque. With the velocity stack + cone, you don't create that vaccum until the car absolutely needs more air.
I'm sleepy now (Hope that helps a bit too...)
Hey, go with OSCAI. That's what I did (I had a Pop Charger and couldn't stand the un-kickyness anymore. (That's what V6s are famous for!!)
Old Aug 29, 2001 | 02:07 AM
black019's Avatar
you so totally made up my mind. now i gotta find someone to install it once i get it...
Old Aug 29, 2001 | 02:24 AM
TurDz's Avatar
hey hey wait a minute! I hope you're not getting CAI...heheh. Get the Poorman's version. Cheaper, effective, and quiet (w/ a little growl at WOT). I think it's nice when an I30 is quiet.
Old Aug 29, 2001 | 10:25 PM
black019's Avatar
oh this I30 will not be quiet when Im done with it. I like noise. noise is good...
Old Aug 30, 2001 | 10:23 AM
BriGuyMax's Avatar
I have NEVER noticed any loss of low end with the popcharger, actually low end is MUCH increased, If I put the car is first gear with the clutch fully engaged (foot off pedal), and roll at about 3-5 mph and then punch it...the tires INSTANTLY break loose, before I did any mods...they car would get up and go, but not with that kind of authority.
Old Aug 30, 2001 | 10:34 AM
Sonic's Avatar
Bri, you keep missing the fact that everyone that reports low end power loss has an automatic. A 5 speed can launch above the power loss, while the automatic cannot.
Old Aug 30, 2001 | 05:24 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Hmmmm....
I have an automatic w/a pop charger, and I noticed NO loss in low-end power.
Old Aug 30, 2001 | 07:36 PM
JoesMAX's Avatar
i just had a stillen intake and i sold it to get a CAI... i think the CAI is nicer because the low end is slightly better... try driving in a car with each of them if possible
Old Aug 30, 2001 | 07:42 PM
JoesMAX's Avatar
Old Sep 1, 2001 | 06:47 PM
Neice Anne
[QUOTE]Originally posted by Turd Ferguson
[B]Think of it like this.
Well it should be noted that with the power/comfort switch on POWER the gears change at the bottom of the redline.
Old Sep 1, 2001 | 07:41 PM
190hpKiLLA's Avatar
Granny Driven
I have a pop-charger and have absolutely no power loss at low end. I once was going around 10-15mph in first gear @ 1000rpm. My foot was off the clutch. I floored it and still got a nice wheel spin. I was trying to scare a civic in front of me.
Old Sep 1, 2001 | 08:41 PM
MaXAnDy's Avatar
just get a pop charger, no hole in ur car and its a lot cheaper and its barely any difference.
Old Sep 1, 2001 | 08:51 PM
Craig Mack's Avatar
And no low end power loss for automagics!!!!
Old Sep 1, 2001 | 10:36 PM
black019's Avatar
but cold air sounds so much cooler...
Old Sep 1, 2001 | 10:56 PM
JoesMAX's Avatar
i like the CAI better than the stillen intake... when i got the cone intake i couldnt belive i was losing low end, i almost got rid of it... like black019 said, a CAI is cooler lol... with a cone its just like, oh thats all it does? replace the box with a big filter that can breathe better... the CAI looks nice and it works well... i put my hand on the part where it goes into the fender underneath the fuse box, and the pipe was cold.. this was after driving for about 10 minutesm so i guess it does what its supposed to
Old Sep 1, 2001 | 10:59 PM
black019's Avatar
woo hoo! some support!
Old Sep 1, 2001 | 11:16 PM
ohboiya's Avatar
do u have the y-pipe as well?
I definately lost low-end with the SI .. I think the majority of people on board would agree .. but the y-pipe more than compensates for this loss ...
Old Sep 1, 2001 | 11:36 PM
JoesMAX's Avatar
the low end loss is hard to explain if you havent driven with the intake yourself... if you take off from a dead stop youre fine, but once you ease off the gas to let it relax id say from like 20-40, when you give it more gas it is hesitant... more gas, still hesitant, then finally it says FINE ILL GO FASTER! and your rpm's jump up like crazy... its annoying having the rpms jump up when youre not wanting them to, to me it felt like a 4 cylinder when that would happen... so black019, take some good advice and go for the CAI, trust me you wont be disappointed (as long as you install it properly lol) just dont forget when you mess with something like an intake, you can easily mess up your engine if you dont know what youre doing... if you have any questions about it you can email me at Joewitthamaxima@aol.com let me know which you go with
Old Sep 1, 2001 | 11:50 PM
BriGuyMax's Avatar
Medic-
I explained before that I don't "launch" it to test for a loss of low end. I just sit at 1000 rpms with the clutch fully out. and then floor the car....simluating how an automagic would work. the tires just spin like crazy.
-Bri
PS - people have dynoed and there is NO power loss down low....it's just a myth.
Old Sep 2, 2001 | 05:16 AM
Sonic's Avatar
Hmmm, it now seems like 50 percent of auto owners report a loss, while 50 percent do not. Time for a pol.
Old Sep 2, 2001 | 06:09 AM
ohboiya's Avatar
I don't think it's a myth .. my butt dyno .. as inaccurate as it is ... without a doubt indicated a loss in low end ...
Old Sep 2, 2001 | 08:04 AM
JoesMAX's Avatar
ok i can personally guarantee that it takes away from low end... like i said when youre doing about 20-40 at low rpms with your foot off the gas or slightly on it, thats when its going to occur... when you give it a little more gas it doesnt do much at all, a little more same thing, a little more again still not speeding up much then your foot is down enough on the gas that it jolts up... a million times my rpms have jumped up without intention... it would be annoying sometimes because 4 cylinders do that... if it was just me i would say maybe its my car but tons of people have said it with autos
Old Sep 2, 2001 | 01:00 PM
BlackMax62's Avatar
so...
im installing my CAI from PR tomorrow...so ill have to post about my opinions after im done.. but what your all saying is that im going to lose high end power and gain some low end power...or is the SI just better at improving high end power....ill post my reactions tomorrow when im done the install...
saber
Old Sep 2, 2001 | 01:13 PM
black019's Avatar
Re: so...
saber
let me know how hard the install is too. I may have to find someone to install mine when I get it.
Old Sep 2, 2001 | 01:28 PM
BlackMax62's Avatar
install
the install should be farely easy...for the 98 model it seems a bit easier...it shouldn't take more than 2 hours at the most...it comes with very explicit directions with pictures that are easy to follow...just thought i would let you know...
saber
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Sep 27, 2015 08:37 AM
