Confused about redline oils.. please help..
Old Oct 26, 2000 | 04:49 PM
petenycmax's Avatar
ok so i go to there website and they have like 8 diff oils.. I have a 97 se 5 speed and i was wondering wich one of the transmission oils would work best for me also how many quarts would i need? One more question any one know of any good differential oil? thanks
Old Oct 26, 2000 | 04:51 PM
Jeff92se's Avatar
I'm needing a caw
Look in your owner's manual for the correct TYPE of tranny oil, then match it up w/ the Redline one.
As far as differential oil, you don't have a choice. In FWD cars, the differential is enclosed inside the transmission case. Unless you thought your car was RWD?? J/K
Old Oct 26, 2000 | 04:57 PM
petenycmax's Avatar
rwd max........ i wish lol
Old Oct 26, 2000 | 06:05 PM
sleeper's Avatar
reply..
i have a 98 5 sp., i am using redline mt-90. i think there is a stock wt., available also.
Old Oct 26, 2000 | 07:36 PM
Neo Max's Avatar
Unless you have a particularly special need for some reason then you have two choices, MTL (manual transmission lubricant) for trannies with less wear on them and MT-90 which is a bit heavier weight oil that protects worn boxes a bit better. Both are GREAT oils. Don't forget though, you can't drain all your oil in one shot. To get max benefit you need to change it, run for a few hundred miles and then change it again to flush as much of the old oil out. Good luck to you.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
AboveDaCloudz
Oct 8, 2015 11:25 PM
foodmanry
Sep 24, 2015 12:02 PM
