Wiring stock FOGLIGHTS without stock HARNESSES???
Old Sep 9, 2001 | 08:07 PM
thebigsadler's Avatar
Can anyone tell me how to do this?? I want to wire them up to a seperate switch on the dash that I will install, what do I need to wire the fogs up to work like this..??
Stock fogs on a 98.
I don't want to use the stock steering column headlight switch.. I want a seperate button, can anyone provide all detailed info needed for this install???
Old Sep 9, 2001 | 08:21 PM
ny96max's Avatar
i have the same thing on my 96. I bypassed all the factory wiring and ran my own wires.
1) on the back of the housing for each fog light, drill a small hole so that the lightbulb wire can poke through.
2) run a 12 or 14 gauge wire to each fog light wire from step1 and connect them together (run both wires up to the battery
3) connect another power wire to the battery and at the end connect a 30amp inline fuse
(so now you have 2 wires from each fog light and one power wire with inline fuse right next to the battery)
4) now run a pair of wires(12 or 14gauge) through your firewall into your switch
5) now with the wire from step4, connect one end of it to the inline fuse and the other end to the x2 fog light wires
6) as for grounding, the bulbs are independantly ground in each foglight housing. If you have a switch that lights up just run a ground wire from it to the steering column(metal)
7) your done!! just dont forget to shut them off when you leave your car like i always do.
hope this helps bro! let me know if you need any other help
Anthony
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
Hdnseek
Sep 9, 2015 05:55 AM
