Pics of my Car!
Old Sep 20, 2001 | 09:02 AM
pawn's Avatar
Pics of my Car!
Here are the new pics of my car
pawn's Avatar
Old Sep 20, 2001 | 09:05 AM
pawn's Avatar
Old Sep 20, 2001 | 09:06 AM
Sprint's Avatar
looks real nice.. what suspension setup are you running?
pawn's Avatar
Old Sep 20, 2001 | 09:08 AM
pawn's Avatar
im running sprint/konis
Old Sep 20, 2001 | 09:12 AM
Sprint's Avatar
me too.. i love that drop..
what are those 17's?
Old Sep 20, 2001 | 09:15 AM
pawn's Avatar
18's
Old Sep 20, 2001 | 09:27 AM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
Drop looks good
18's
Where are the centercaps?
Old Sep 20, 2001 | 09:30 AM
pawn's Avatar
Re: Drop looks good
i know..paul forgot to ship them....he's supposed to be airmailing them too me.....hopefully soon
Old Sep 20, 2001 | 09:33 AM
Sprint's Avatar
18's
18's? what size tires are you running?
Old Sep 20, 2001 | 09:38 AM
pawn's Avatar
225/40ZR18
Old Sep 20, 2001 | 09:40 AM
Sprint's Avatar
225/40ZR18
thats your problem.. your speedo is way off.. and i notice that your tires look too big..
http://forums.off-topic.net/attachme...postid=1037737
i am running 235/40 or 245/45
check this site out..
http://www.miata.net/garage/tirecalc.html
and
https://maxima.org/maxfaqs/sub_tires...#TiresWheels_2
Old Sep 20, 2001 | 09:42 AM
pawn's Avatar
and
my speedo isn't off...that is the correct size for 18's on the max////
Old Sep 20, 2001 | 09:44 AM
Sprint's Avatar
ok if you say so
NickStam's Avatar
get center caps ASAP
Old Sep 20, 2001 | 09:48 AM
pawn's Avatar
then what is the correct tire size???????
Old Sep 20, 2001 | 09:50 AM
Sprint's Avatar
FYI:
with 225/40
your speedo is .8 seconds fast every 1 mph
with 235/40
your speedo is .3 seconds slow every 1 mph
stock tire being 215/55 for the SE ..
but hey.. what do i know
Old Sep 20, 2001 | 09:53 AM
Sprint's Avatar
I can't say for sure if the error starts over 60 mph or over 100 mph
h
FYI:
with 225/40
with 235/40
Old Sep 20, 2001 | 09:57 AM
matt calder's Avatar
i am running 225/40/18's and my speedo is not off either, its a good tire size for 7.5 inch rims.
Old Sep 20, 2001 | 09:58 AM
pawn's Avatar
i don't understand....when i took the stock 16's off and rolled them up to the 18's they were the same size.....
how do i fix the speedo.....
Old Sep 20, 2001 | 10:01 AM
Sprint's Avatar
my son.. its not something you will notice driving.. the only way you can tell is by a radar gun (ie. The cop tells you that you are doing a speed differnt from what your speedo indicates) its not really a big deal right now.. i would just advise you to get the correct size next time... and that is how you fix the speedo problem..
i noticed because i looked at how thick your tires were compared to mine.. the correct tire size or closest to it is 235/40-18
Old Sep 20, 2001 | 10:04 AM
pawn's Avatar
i thought the middle # was how thick they were!
aren't you running like a 2--/45/17
Old Sep 20, 2001 | 10:07 AM
Sprint's Avatar
nope..i am running 235/40-18
when i said thick i meant the size of the tire wall
Old Sep 20, 2001 | 10:18 AM
pawn's Avatar
[B]
when i said thick i meant the size of the tire wall...
that's what i meant....the middle number=sidewall width...and the first # is the actual width of the tire itself....
225=how wide tire is
40=sidewall width
cuz a 19" rim uses a 35 series tire...which is more of a low profile tire than the 40 series
Old Sep 20, 2001 | 10:29 AM
Sprint's Avatar
huh? what?
anyway.. 235/40-18 is the right size
40=sidewall width
Old Sep 20, 2001 | 10:34 AM
pawn's Avatar
huh? what?
what does the 1st number stand for?
and the second?
Old Sep 20, 2001 | 10:35 AM
Shadow's Avatar
If he's running tires too small for the Max, why would his tires look thicker than yours? He has 225/40/18, you have 235/40/18. Your tires are bigger than his, so why do you say his look thicker?
Sprint's Avatar
and the second?
i thought 235 was the side wall tire and rim and 40 was the width
Old Sep 20, 2001 | 10:39 AM
pawn's Avatar
i think you have it backwards.....
that's what i was trying to say.....
Old Sep 20, 2001 | 10:42 AM
yeah you have it backwards. 235 is the part of the tire that rolls on the ground, 40 is the sidewall height.
Old Sep 20, 2001 | 10:52 AM
BRIGBOY's Avatar
I don't think .8mph to 1 sec makes a diff...
....I am running 225/40/18's and my speedo is as close as its gonna get. Radar tested, officer approved.
Old Sep 20, 2001 | 12:26 PM
TurDz's Avatar
anyway, I'm glad I did lots of reasearch before choosing my tire size
This is a great link I remembered using when I first bought the tires:
http://www.geocities.com/jgadlage/tirecalc.html
Old Sep 20, 2001 | 12:52 PM
Sprint's Avatar
wether i have it backwards or not you are still running the wrong tire size
Old Sep 20, 2001 | 12:54 PM
Sprint's Avatar
Re: I don't think .8mph to 1 sec makes a diff...
well if its .8 over 60 mph.. if you are doing 70 mph .. thats 10 * .8 so thats 78 mph you are actually doing when your car says you are doing 70 mph..
if its over .8 over 100 mph.. it won't matter too much because most people don't drive that fast.. but then.. it would be 108 mph when indicated doing 100 mph and so on...
Old Sep 20, 2001 | 01:04 PM
Shadow's Avatar
Re: Re: I don't think .8mph to 1 sec makes a diff...
Sprint, his tires are smaller than yours so how could his speedo be reading low and yours isn't? You are running 235/40/18 tires which are bigger than the 225/40/18 tires he's running. His speedo would read high, not low. Your speedo will read low.
Old Sep 20, 2001 | 01:08 PM
Sprint's Avatar
Re: Re: Re: I don't think .8mph to 1 sec makes a diff...
yeah i know..
mine is .3 secs slow.. his is .8 secs fast..
according to the miata calculator
Old Sep 20, 2001 | 03:49 PM
Lordrandall's Avatar
Guys, the second number is not a constant measurement, it's an aspect ratio. Check out this page on tirerack for a full explination.
http://www.tirerack.com/tires/tiretech/size.htm
A 235/45 tire is going to have more sidewall than a 215/45 tire.....
Old Sep 20, 2001 | 04:19 PM
redmaxpa007's Avatar
i SeE what you did therE
kewl... looks good
Old Sep 20, 2001 | 05:40 PM
Greg's2kGLE's Avatar
If I remember when Paul had the rims on his car (I saw them in person), those rims are 8.5" wide. That is why his tires look huge. A guy at the same meet, had the same size tire on a 18"x7.5" (or even a 18"x7") and Paul's tires (now pawn's) looked fatter. Honestly, I think the tire size shoudl be 235/40/18 for your car. I think Paul's car had the 15" SE rims before hand and that's why he might have went to 225/40.
