Pics of my Car!
Old Sep 20, 2001 | 06:11 PM
  #41
NYCe MaXiMa's Avatar
hmmmm
235/40/18
defined like this:
width of tire (flat surface that touches the ground) / sidewall height (40 size would be "thinner" then a 45 size) / Diameter of rim.
The sizes are usually matched like this:
stock SE 4th gen rim is 6.5" wide, factory tire is = 215/.../...
Stock 17" SE 2k rim is 7.0" wide, factory tire is = 225/.../...
They usually go up in 10 pts. though the proper size for a 8" wide rim is 235.. although a 245 will fit.... they vary a little bit in width.. people put 225 wide tires on 6.5" SE rims all the time. They fit normally.
The 1st # is the tire width, which should NOT affect overall turning diameter.. it might feel different or slower because the surface area is slightly bigger... it's all physics and crap.. anyways, only the middle # and the last # affect the turning diameter which will throw off the speedometer readings if it's bigger then stock... if they are matched up wrong, then the reading would be off..
Old Sep 20, 2001 | 07:51 PM
  #42
pawn's Avatar
Originally posted by redmaxpa007
kewl... looks good
thanks....
would look better w/the trenz lower valence!!!!!!
Lakersallday24
Jun 16, 2019 01:35 AM
Quickgtp
Apr 13, 2017 03:30 PM
halfpol
Aug 5, 2015 08:24 PM
