Question about automatics chriping while shifting to second...
Old Sep 24, 2001 | 07:50 AM
ivolley's Avatar
I have a 96 SE with the normal mods Y pipe/CAI/ yes it is an automagic but the shifts are not tight enough. I previously owned a 91 Acura Legend Sedan auto the car weighed about 3400 lbs and had 200hp and 210 ft/lbs of torque and even with 180K miles I would get a distinct chirp as it shifted to second after I would gun it. I do not recall if it went to redline but the Maxima shifts well, but I am no where near chirping the tires. I will say with the Maxima the downshifts in the 40-60 feel stronger than the Legend did. Does honda make stronger transmissions or does Nissan ecus not push the trannys to shift at higher RPMS.
Pat
Old Sep 24, 2001 | 07:57 AM
Sonic's Avatar
They only way you are going to get the chirp is forced induction or a ValveBody upgrade. You can then chirp second with a completely stock setup. www.mobiletek.net or www.levelten.com
Old Sep 24, 2001 | 08:05 AM
Synki's Avatar
First thing i would have don e was the VB mod. The weakest point in the Maxima is teh auto tranny. Get the VB mod to eliminate this problem.
I have had my VB mod since 20k miles & its 20k miles later. Tranny still never misses a shift & shifts faster then a 5spd ever will. 5spd guys are amazed at how fast it shifts (so that is respect there).
My 1st to 2nd gear really doesnt chirp but sometimes wheel hops or just flat out breaks out spinning. This is ony when i have my steel rims on. WHen i run my chrome rims i get chirps. Its a beautiful thing.
Old Sep 24, 2001 | 08:15 AM
Sonic's Avatar
Synki, I had Sprint and his two cousins in the car with me and we STILL chirped second(VB kicks ***)! I can get wheelhop occasionally, but its usually the chirp I get. Then again I have never driven with the VB and 15s on.
Old Sep 24, 2001 | 09:56 AM
Synki's Avatar
Re: ValveBody Upgrade
Originally posted by slammed95
Wow guys that sounds awesome. I can usually chirp into second with my stock tranny so I can't imagine how much quicker it would shift with the VB upgrade. Now I really want one. Where can get it?
2 places. Either go to Level10 in NJ (if your close) or talk to "Don in Texas" on this baord. He has done most of our VB mods.
Old Sep 24, 2001 | 10:13 AM
Sonic's Avatar
I guess you didn't click the 2 website links I provided. Oddly enough they go to 'Level10' and 'Don in Texas' websites.
Old Sep 24, 2001 | 10:31 AM
Cumalot's Avatar
WTH? I had Don's VB on for about 2 weeks. I have yet to chirp second gear. I'm riding on my 17s though, do the rims affect it in anyway? And yes, I was flooring it.
Also, is it the tires? I got Dunlop SP9000 on my Tantrums.
I CANNOT CHIRP SECOND!
Old Sep 24, 2001 | 10:35 AM
Sonic's Avatar
It must be you then. Everyone I have talked to has been able to, even the big rim boys.
Old Sep 24, 2001 | 10:42 AM
Cumalot's Avatar
Synki said he doesn't really chirp 1st to 2nd either. I do get a sort of a hop, but not a chirp. Hm...then again, most of the time I had my music blasting, maybe I just didn't hear it?
Old Sep 24, 2001 | 10:44 AM
Sonic's Avatar
There you go. You should be able to get SOME type of wheelspin.
Old Sep 24, 2001 | 10:50 AM
Synki's Avatar
Its amazing the type of noises you hear from your car when the volume of music is down. SOme are annoying creeks and sometimes its your tires chirping.
Old Sep 24, 2001 | 10:56 AM
Sonic's Avatar
I have a '95, no creaks here.
Old Sep 24, 2001 | 11:03 AM
Cumalot's Avatar
Well, that's the primary reason why I always have my music on. Everytime I turn the music off completely, I would get a few odd noises from time to time. Maybe I been blasting my music for too long because some people told me I have a hearing problem. What? I said I think I have a hearing problem. What? I said...
Old Sep 24, 2001 | 12:32 PM
Dave B's Avatar
Not DAVEB the parts guy
Chirping into 2nd is largely based on the condition of the tranny clutches, valvebody line pressure, fluid temperature, tire/wheel combo, and most importantly the surface conditions. Some streets are simply more slippery than others. It has been my experience that flat/wide low profile tires are much more prone to wheelspin. My 235/45R17s would spin so dramatically into 2nd sometimes that I'd have to back off. It was fun to show off, but it slowed me done a lot. My 215/55R16s only chirp into 2nd now.
I wouldn't be too worried if you can or can't chirp 2nd gear. My modded automatic 94 Z28 would chirp 2nd every once and a while. It ran mid 13s with or without the chirp. Most modded Grand Prix GTPs pushing nearly 300fwtq and running AWESOME 4T65E GM trannies rarely chirp into 2nd and still pull low 14s/high 13s.
Dave
Old Sep 24, 2001 | 02:45 PM
mtrai760's Avatar
'Trynna' is not a word
I sometimes chirp second, sometimes spin a little(off the bottle), depends on the temp outside, if it's hot it doesn't usually do it. I have the transgo kit and 225/50/16 Kuhmo's...
Mar 12, 2020 12:06 AM
Maximan190
Dec 16, 2015 06:01 AM
QueensMAX
Sep 15, 2015 04:14 AM
videomano
Sep 8, 2015 03:28 PM
