PA systems
Old Sep 24, 2001 | 01:24 PM
superblackmax
PA systems
anybody know anything about intstalling PA systems in maxs? A friend just put one in his 95 eclipse that he got out of a retired firetruck, but I'm not that lucky so I was hoping I could buy one from somewhere (relatively cheaply I might add) or put together a custom job. If any of yall know anything let meknow/.
mitch
Old Sep 24, 2001 | 02:09 PM
SuDZ's Avatar
Re: PA systems
mitch
What sort of setup did he have. For instance I once set up a CB radio in somones car that had the PA option. I used an external speaker and just ran it to the PA attachemtn. All that had to be hooke up was the CB which if youwant just for the PA then you dont even need an antena or anything. Just run the speaker to it and use the mic that comes with it. I even hid his under the plastic that is under the steering wheel and above his knees. This was not in a Max but the same idea none the less. Or even under your seat would work and there are already power cables there. If you got the powerseat option.
SuDZ
Old Sep 24, 2001 | 02:47 PM
pawn's Avatar
why?
Old Sep 24, 2001 | 02:58 PM
superblackmax
Re: Re: PA systems
SuDZ
yeah, hes got a CB but Im pretty sure hes not even runnin the PA through it. You know where I can pick up a PA system for as little money as possible? (i still want it to work and sound good though)
Mi-atch
Old Sep 24, 2001 | 03:04 PM
pawn's Avatar
Re: Re: Re: PA systems
Mi-atch
I still don't understand why you would want this???
Old Sep 24, 2001 | 03:26 PM
superblackmax
Re: Re: Re: Re: PA systems
Hell, bro, I don't know. Itd just be fun to have it was cheap. Its not like im gonna go out and spend 800 bucks on a toy. Actually I really would like to get a CB - they can be useful for all sorts of stuff. just checkin into it.
mitch
Old Sep 24, 2001 | 03:42 PM
pawn's Avatar
I would try checking truck stops....im sure they would have everything you need there....
Old Sep 24, 2001 | 03:54 PM
superblackmax
yeah, good call. Ill check into that
mitch
Old Sep 24, 2001 | 03:56 PM
pawn's Avatar
mitch
no problem
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
RWCreative
Sep 21, 2015 11:01 AM
