Bumping up the Idle question??
Old Oct 30, 2000 | 09:20 AM
ny96max's Avatar
i have recently raised the idle of my car from 550 - 800 while the car is at an idle in park. will this screw up anything in the car by messing with the TPS???
Old Oct 30, 2000 | 09:48 AM
The_quorum's Avatar
I've tried...
and the car just resets it right back...I've tried both extremes messing w/ that screw, including resetting the ECU with the new settings...each time, it moves right back. Good luck though.
Old Oct 30, 2000 | 10:16 AM
Victim64's Avatar
whats that hissing sound???
When I adjust my screw and raise my idle my intake will start to give off this small hissing sound. Is this normal or should I not adjust it to this point?
Old Oct 30, 2000 | 11:15 AM
DDD
Surprising
Hi guys,
How do you manage to adjust the idle velocity with only one screw? As far as I know the idle rpm is stored in the ECU's RAM and cannot be changed.
Maybe you're adjust the TPS (simulation of slightly pressed throttle pedal) instead of the idle ?
Regards,
DDD
Old Oct 30, 2000 | 07:03 PM
sleeper's Avatar
adjust idle..
i have adjusted my idle screw from 550 to about 700. it seems to be fine. no stalling. i have heard that a rule of thumb is not to adjust over 2/3rds of the original idle speed. so if the original is 550rpms then it would be 733rpms, max. (thats just my info),i just turned the screw (counter-clockwise, i believe it is), and listened to the idle until it sounded smooth. not to push anything upon anyone. it's cold.
Old Oct 30, 2000 | 08:08 PM
mingo's Avatar
hmmm... newer cars they ecu just sets the idle back to stock. it works on the old school carberated cars tho. i'm not sur ebut i think the afc can also do idle rpm.
Old Oct 30, 2000 | 08:55 PM
Carlos A's Avatar
I have done it, no problem
Greetings,
I have done the Idle rise with the screw setting. Didn't have to disconnect the sensors.
I have raissen the Idle from +- 500 to 800 rpm. It has not gone back down by itself.
I have a 96 SE though (that may be the reason).
I noticed though, that after I istalled my Stillen Y the idle dropped about 50 rpm, I think this is due to the new compensation values the ECU has converged to. I might have to rise the extra 50 to get back to 800.
Old Oct 31, 2000 | 06:00 AM
mitster
I have a 97 SE auto and I used the screw to bump up my idle so my steering wheel would not shake at night with lights on. I did notice two things in adjusting the screw. 1. The more I turned the screw I got a louder hissing sound from around the intake. 2. I noticed a ticking sound also as the idle got higher. I set mine so at night in drive with lights on the idle is 650rpm. no more vibratating wheel, no ticking, minor hissing. I have had this set like this for a month and starting, performance, MPG all seem fine.
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
