Rewired my fog lights...
Old Oct 2, 2001 | 11:30 AM
97GreenMax's Avatar
I did my foglight rewire yesterday. It was very very easy, and looks great. I'm glad I finally did it instead of putting it off some more. It only took about 20 mins and well worth it.
Old Oct 2, 2001 | 11:50 AM
Kevin Wong's Avatar
can you summarize what you did
The instructions looked a bit difficult. 20 minutes is well worth it for me. I've been wanting to fiddle with the fogs for some time.
Old Oct 2, 2001 | 11:58 AM
breaux124's Avatar
Re: can you summarize what you did
Here you go
http://www.users.voicenet.com/~breau...fogrewire.html
I made it as simple as posssible.
Old Oct 2, 2001 | 12:31 PM
Kevin Wong's Avatar
thanks
I tried doing this before and got stuck with the fuses. I got the top off, but didn't know how to remove the fuses. Your pictures are very helpful...now I know what it should look like. I was scared to break my fuses and fusebox as I had no idea how to remove them. Thanks again.
Old Oct 2, 2001 | 12:40 PM
breaux124's Avatar
Re: thanks
They're relays, not fuses. Just to clarify
Old Oct 2, 2001 | 12:57 PM
SEguy182's Avatar
the max has the best headlight and fog configuration, like the placement of both just make the max a great looking car in my rearview at night, the foglight mod is just another bonus
Old Oct 2, 2001 | 03:09 PM
97GreenMax's Avatar
I used the site that Bryan made and sent. The directions were very easy. Instead of a wire tap, I soldered the wires togather and taped them up.
Old Oct 2, 2001 | 03:38 PM
Kevin Wong's Avatar
Re: Re: thanks
So you see my problem
Old Oct 2, 2001 | 03:46 PM
ToYLeT902's Avatar
JET Speed Lab
Old Oct 3, 2001 | 12:33 PM
dashingMax's Avatar
Re: Re: can you summarize what you did
Here you go
THANK YOU VERY MUCH!
The picturs are VERY HELPFUL!
Old Oct 3, 2001 | 12:37 PM
breaux124's Avatar
Re: Re: Re: can you summarize what you did
You're Welcome.
Just wanted to give something back to the community.
Actually there are instructions with pictures for just about every install job on the maxima. You just need to know where to find them.
Old Oct 8, 2001 | 02:40 PM
dashingMax's Avatar
Re: Re: Re: Re: can you summarize what you did
You're Welcome.
I successfully rewires the Fogs...
Good instructions, muchos gracias
Old Oct 8, 2001 | 03:51 PM
Mishmosh's Avatar
Yeah it is easy. Basically amounts to clipping one wire from the foglight relay, and then tapping a 3ft wire from that to your corner lights. All the other instructions is how to dismantle and remove the relay/box. You can get wire and wire taps from Radio Shack for cheap.
Old Feb 13, 2002 | 07:26 PM
maxima168's Avatar
NEED HELP
after the foglight mod did u guys noticed that the corner lens is dimmer then the driver side one?
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
