Info 4 everyone on aftermarket springs and coilovers
Old Oct 7, 2001 | 12:44 PM
JAY25's Avatar
Aftermarket springs are made for a more comfortable ride quality, whereas constant rates are for the more serious enthusiast. With progressive rate springs, if you hit little bumps, the spring is made to absorb those more like stock springs (softer) so the ride stays semi-comfortable. If you corner hard with your car and you're putting more stress on the springs for them to compress, they will compress less. Supposedly, at high speeds, the springs will compress a little and you will get better handling. Most sport springs come in progressive rate and many race springs come in constant rate. If you imagine looking at a spring and the coils are evenly spaced out, you can think of this as a constant spring rate. If you modify the spring so that as you go from the bottom to the top, the coils are spaced a little bit less, then this is (basically) a progressive rate spring. The little bumps will be absorbed by the softer coils, the hard turn will be held in by the stiffer coils. This is much more practical since the spring basically meets the needs of the road.
Coil-Overs: the solution to all problems??
Coil-overs are an adjustable spring and strut combination that gives you the ability to adjust the actual height of your car. The spring sits on a little adjustable perch that can be adjusted up and down, by simply screwing a little piece up and down and locking it in place. Think of this as your spring and strut sitting on a large screw that can be adjusted up and down. Every coil-over that I've heard of uses a constant spring rate which is one of the downsides to using them. The obvious advantage is that your car can be raised or lowered without going to a shop. Simply jack up that wheel, remove the locking mechanism and turn the screw up or down. This is great if you want your car slammed, but want to be able to raise it up if you need. If your car is too low, then many places cannot get it on a lift to work on it, so you're kind of stuck with a broken (but nice looking) car. You might want to raise your car a little for winter... or for a trip to the city... whatever the case, coil-overs are a very good solution to the lowering needs of enthusiasts. The downsides to using coil-overs include the fact that they are more expensive and that, after a lot of use, the threads on the coil-over can wear out. Some coil-overs come with a spring and a strut (more expensive), others come as a kit, where you attach them to your existing strut/shock.
got this info for everyone
[img]C:\My Documents\My Pictures\MAXORG copy.jpg[/img]
Old Oct 7, 2001 | 05:57 PM
gregulator's Avatar
thanks for the collection of info, but gives me an idea. if the perch on coilovers for the spring is somewhat of a standard spring diameter then why couldn't you just buy a perch and put any spring you want on it... i.e. put something on that is progressive but provides the least amount of drop... perhaps even the original springs or maybe H&R's? Is this possible? I guess i need to see a good picture of coilovers to get an idea of what the assembly looks like. maybe i can weld something up that would make a combo like this work. any ideas/obvious things i am missing?
Old Oct 7, 2001 | 06:54 PM
BRIGBOY's Avatar
Don't GC's use Eibachs?
And aren't Eibachs progressive?
Old Oct 7, 2001 | 11:18 PM
Nealoc187's Avatar
SLOW
eibach makes both progressive and linear rate springs. the springs they use for the GC coilovers are linear rate.
Old Oct 8, 2001 | 07:48 AM
srbarnes4ever's Avatar
In the case of Ground Control coilovers with Eibach linear rate race springs, the ID of the spring is only 2.5" and the spring perch (adjustable portion) is made for that ID. Your stock springs are much larger ID and will not sit on the perch. Therefore no adjustment is possible. If you get struts and springs mated with similar rebound/compression characteristics, you can end up with a very stock feeling ride during normal day to day driving and very nice race/auto X day driving tendencies as well. But that strut to spring rate matching is much easier said than done. I have GCs on my Ford Escort (don't laugh, this car hugs corners with the best of em!) with 300# front and 200# rear linear Eibach springs mated to Tokico blue struts. The car is a blast to drive on back roads and stuff, but the springs really are too strong for those struts so the car bounces all over the place on normal, beat up roads. I think I have it lowered too much also which makes the ride a bit harsher by reducing compression travel of the strut....Anyway, hope I haven't muddied the waters too much! Good luck in your search. I've heard lots of great things about the Eibach Pro-kit spring and strut combo. They are precisely matched sets of springs and struts that are designed for specific models of vehicles. Unfortunately I don't think they have a set for the Max..... ...
chisam14
Nov 6, 2018 08:56 PM
bigdogsteve
Jan 31, 2018 04:18 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
followthadollar
Sep 27, 2015 01:06 PM
