got new shims..which pad gets 2 shims, and the other just1?
Old Oct 10, 2001 | 06:52 PM
buss95max's Avatar
i got new shims from the dealer today..theres 4 black plates, and 2 silver smaller metal plates.
which pad gets the silver and the black? what goes on top of each other?
anyone??????
Old Oct 10, 2001 | 08:08 PM
emax02's Avatar
Re: got new shims..which pad gets 2 shims, and the other just1?
anyone??????
The inside brake pads get the 2 shims{Closest to wheel well}. The out side pads only get one shim. If I can recall correctly, the black shim goes over the silver shim on the inside pads. It's hard to make out what color my shims are becuase they had over 100K miles on them last time I did my pads.
Old Oct 10, 2001 | 08:27 PM
buss95max's Avatar
aw man....
i just did the opposite...
Old Oct 10, 2001 | 08:53 PM
buss95max's Avatar
Re: aw man....
u think it will be ok till i fix it?
Old Oct 10, 2001 | 09:24 PM
emax02's Avatar
Re: Re: aw man....
, to bad I did not anwer your question sooner, I whould have saved you some time. I guess the shims will be fine in the mean time, I don't think they do a whole lot anyways, but I could be wrong.
Old Oct 10, 2001 | 09:26 PM
buss95max's Avatar
aitteeee....
Old Oct 11, 2001 | 06:56 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: got new shims..which pad gets 2 shims, and the other just1?
the inside pad is the other way around. it's the black one then the bronze/shiney one over that..on the inside pad. outside pad only the black shim.
Old Oct 11, 2001 | 07:06 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Re: Re: Re: got new shims..which pad gets 2 shims, and the other just1?
I agree with DanNY on this one, as the shiny metal shim is for the caliper piston to press against, while teh black shim goes directly on the pad.
However, please note that my 99 had significant noise when using the shiny metal shim and much less when using only the black shims. The caliper piston "eats" through any brake disc quiet (blue goop) that you may place on the shiny metal shim. Any front brake noise rarely occurs and is barely audible.
Old Oct 11, 2001 | 07:22 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: got new shims..which pad gets 2 shims, and the other just1?
bill try slapping some of that blue goop of yours between the shiny shim and the black one. or adjust the shiney one so it's more snug on the pad. worst case get a new set of shims from nissan.
Old Oct 11, 2001 | 07:41 AM
bill99gxe's Avatar
Re: Re: Re: Re: Re: got new shims..which pad gets 2 shims, and the other just1?
I did.....it didn't help.
What occurred was the layer of blue goop that I put on the OUTSIDE of the shiny metal shim was worn through by the caliper piston, producing copious amounts of noise only a few weeks after they were blue gooped.......
So I left that shim off when I took everything apart again, and all is quiet.
Old Oct 11, 2001 | 07:47 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Re: Re: got new shims..which pad gets 2 shims, and the other just1?
woah..that's odd...sounds like the spring for the pads are a little weak.
well as long as it's good now..
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
05RLS2
Sep 27, 2015 09:24 PM
bbsitum
Sep 11, 2015 04:55 PM
